View Poll Results: A poll
Edelbrock Performer
50.00%
Weiand Xcelerator
7.14%
Weiand Stealth
7.14%
Power Plus Typhoon
0%
Power Plus Cross Wind
0%
Other (explain)
35.71%
Voters: 14. You may not vote on this poll
Which manifold?
Old May 5, 2005 | 02:38 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default Which manifold?
Which manifold would you prefer as an upgrade to the stock manifold?
Old May 5, 2005 | 08:10 PM
69FECoupe's Avatar
69FECoupe
Default RE: Which manifold?
I voted for one that's not listed, the Performer RPM. The standard Performer isn't much more than a lighter stock manifold. The RPM is designed to work with a more aggressive cam at a higher RPM.
Old May 5, 2005 | 11:28 PM
DSMtuner's Avatar
DSMtuner
I chose the Edelbrock RMP Air-Gap. If clearance permits.. I dont think its that much taller than the typical aftermarket intake mani.
Old May 5, 2005 | 11:52 PM
Magiarn71's Avatar
Magiarn71
I have an air gap and a 1 inch spacer with a k+n air cleaner and I can still close the hood
Old May 6, 2005 | 01:40 AM
67coupe's Avatar
67coupe
It depends on what the rest of your engine build and rear gear ratio are. I have had three different intakes on the same engine. Ported heads with 1.94 and 1.50 valves. 10.9:1 compression and a 288 duration .465 lift cam. The Performer RPM and the old F4B intake were about the same peaking around 5,500-6,000RPM with a 750 Holley. The best mid to high RPM power it ever had was with a Holley Street Dominator. The low end was not much less than the other two and it would pull another 1,000 RPM before fading.
So if you run some engine mods, 3.50:1 or more rear and a higher stall convertor if you have an auto then go for the single plane intakes. If you are pretty much stock get a Performer RPM and a small carb.
Old May 6, 2005 | 11:01 AM
jrrhd73must's Avatar
jrrhd73must
ORIGINAL: Magiarn71
I have the performer and can still close the hood. Before the MSD, petronix, and dual exhaust she dinoed at 387 horsepower[8D]
Old May 6, 2005 | 01:16 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, I was reading somewhere that the Edelbrock Performer is nothing more than a stock manifold that's made out of aluminum, and that there a whole bunch better manis out there.
mrtrodonet
Sep 19, 2020 03:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
mustangheaven
Sep 29, 2015 11:00 AM
