Two Stoplight Switches???
Old Jul 14, 2008 | 02:58 PM
unit91's Avatar
unit91
Default Two Stoplight Switches???
I haveswitches on the brake pedal andon top of the master cylinder. What's the one on top of the master cylinder for?
Old Jul 14, 2008 | 03:19 PM
Starfury's Avatar
Starfury
Default RE: Two Stoplight Switches???
On top of the m/c? There shouldn't be anything on top of the m/c except the zinc-coated cap. There is, however, a switch on top of the distribution block. That's part of the pressure differential switch for the brakes; it lights up the dash brake light if one side of the brake system loses pressure.
Old Jul 14, 2008 | 06:15 PM
kalli's Avatar
kalli
64 1/2 mustangs have the brakelight switch on top of the master cylinder. maybe you got one of those?
disconnect the cable there and see if your brakelights still work/. Then you'll know which of the switches is used
Old Jul 14, 2008 | 07:20 PM
Starfury's Avatar
Starfury
looks like a 67/68 in the pic, though. Don't know why anyone would put a single-bowl m/c in one.
Old Jul 14, 2008 | 08:30 PM
unit91's Avatar
unit91
OK. My bad. It's a 68 Mustang, and it has a dual bowl master cylinder with two lines coming out of it. The switch is on one of those lines, not the top of the master cylinder. Sorry. So what have I got there?
Old Jul 15, 2008 | 03:57 AM
kalli's Avatar
kalli
make a picture sure.
They only ideas that come to my head are:
stoplightswitch, brake warning as Tad says and low brakefluid level warning.
Kalli
Old Jul 15, 2008 | 11:18 AM
Starfury's Avatar
Starfury
On one of the lines? Or on the brass block on the fender?
Old Jul 15, 2008 | 09:52 PM
unit91's Avatar
unit91
On the line that's closest to the firewall.
Old Jul 16, 2008 | 02:18 PM
jlg2002's Avatar
jlg2002
That switch is the for the Inst panel "Brake" warning ight that comes on when the shuttle in the distribution block senses there is unequalized brake pressure. But I don't see that circuit on a 68. It looks to start in the 69 model year. Is the switch wired?
Old Jul 22, 2008 | 01:20 PM
unit91's Avatar
unit91
Yes, it's wired. The switch is round, has two prongs on the top, and the wires go thru the firewall into the interrior.
