Reverse Lamp Issues on a 69'
Old Jul 21, 2008 | 03:16 PM
Dakmor's Avatar
Dakmor
Default Reverse Lamp Issues on a 69'
I have a quick question that I am sure you all can help me answer
Everything on my car works flawlessly with the original wiring and everything... Except for the reverse lamps. I replaced the neutral safety switch and they are still having issues. The problem is that the passenger side light is not turning on when I reverse. Another issue that I found was that when I purchased new reverse lamps (which turned out to be 68's) neither of those worked (I don't see how different they could be).
This seems to be a really strange problem in my opinion and I hope you guys can shed some light on what is going on.
Thanks.
Old Jul 21, 2008 | 10:49 PM
LCC's Avatar
LCC
Default RE: Reverse Lamp Issues on a 69'
Check the lamp, change it with the one that works. The best thing really is to use a light tester to see if you have voltage and a good ground to the light socket. Hope this is a good start.
Old Jul 21, 2008 | 11:41 PM
4reboy's Avatar
4reboy
make sure its connected into the harness in the trunk? sometimes the simplest solutions turn out to be it.
cr620
Oct 3, 2022 10:18 PM
CS2007
Jun 25, 2019 09:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
UrS4
Sep 30, 2015 10:13 AM
