Best motor setup
Old Jul 21, 2008 | 03:35 PM
travisbarker04's Avatar
travisbarker04
Default Best motor setup
I just picked up a 68 mustang andI am trying to think of a good motor to put in it. Whats the best setup? I want a 4 speed, want to drive it everyday but be able to take it to the track inrun inthe 11-12. I was thinking of going with a 351 stroker maybe? wanted to know what you guys think would be the best setup for me.
Old Jul 21, 2008 | 05:38 PM
Shpongle's Avatar
Shpongle
Default RE: Best motor setup
with gas ...if i where you, i would get a stock create 302, put in a cam, 4 barrel and full exhaust
Old Jul 21, 2008 | 05:44 PM
Shpongle's Avatar
Shpongle
ok i didn't read that you want in 11's... well, if you have a 289, i would get the paxton supercharger made spiciffly for 60's stangs, with some mild performance parts.
[IMG]local://upfiles/97933/53ED1A0D1BD94E98B3151339BDFFBC9F.jpg[/IMG]
Old Jul 21, 2008 | 08:28 PM
67mustang302's Avatar
67mustang302
Dart etc 351 block with 4.125" bore and a 3.75 stroker crank, 400 inches. TFS TW 185 CNC heads with a custom hyd roller cam and all the bolt ons.
Old Jul 21, 2008 | 11:02 PM
travisbarker04
Ok, What tranny shouldI run with that set up? And 351 Windsor or Cleveland? What Years?
Old Jul 21, 2008 | 11:24 PM
ky's Avatar
ky
America ftw
built c4 or a t5. depends on how good of a driver you are.
windsor.
Old Jul 21, 2008 | 11:28 PM
travisbarker04
I am a really good driver lol! Thanks everyone
Old Jul 21, 2008 | 11:32 PM
ky's Avatar
ky
America ftw
well travis barker is a really good drummer
Old Jul 22, 2008 | 12:14 AM
htwheelz67's Avatar
htwheelz67
depends on you budget and how drivable you want it, you can build a stock cammed twin turbo 302 that pulls 11-12's that will be as fuel eficient as a stocker or better at least on the hwy or a blower but not as fuel efficent, a nice 347 or 351w will get you there too,but not as efficient you can also build a 393-408 stroker with a mild or custom cam and taller gears for economy that will get you there too.
Do you want smooth idle and massive power, turbo or 351 based stroker, do you want a racy idle and higher rpms 347-351w 351w if starting from scratch is better and stronger and if you want to grow in cubes you are set up to 428 ci. If you want a stick car dont bother with the 4 spd, get a 5 or 6 spd you will go faster and get better milage and top speed if you want it.
If you want cheap, good mileage and fast, a stock 5.0 shortblock (forged) balanced, AFR 165's or TW heads and 150 shot of N20, power on demand and fuel economy it would make about 350-390 hp + the n20 =500 hp with good traction 11's no problem and 20+ mpgs hwy easily even with the stock HO cam, dont forget OD trans makes a huge difference.
heres mine http://htwheelz.smugmug.com
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
fastbackford351
Oct 1, 2015 12:24 PM
guitarman376
Sep 30, 2015 05:54 PM
logan409
Sep 26, 2015 07:43 PM
