Tire Size Advice
Old Jul 30, 2008 | 12:52 PM
yellow68's Avatar
yellow68
Default Tire Size Advice
I currently run stock Bullitt wheels on my '68. I also run 1" spacers front and back. The fronts have fender issues.
I also have installed Bullitt (Cobra) brakes on all four corners. Running spacers sorta hides the pretty red calipers by placing them further back from the face of the wheel.
So, I have decided to run aftermarket Bullitts, but 17x9 out back and 17x8 narrowed to 7" up front. This will place the wheels perfectly at each corner.
Stock Bullitt tires are 25.7" tall. 275/40/17 out back will be 25.6" tall. No-brainer. Up front, I'm between a 225/45/17 and a 225/50/17. The first will be 25.0" tall and the second will be 25.8" tall.
I think both will work, but can't decide which to go with up front.
Old Jul 30, 2008 | 01:18 PM
davesanborn's Avatar
davesanborn
Default RE: Tire Size Advice
The section width of a 225 series tire is 8.85". That's a pretty wide footprint when used on a 7" wheel on the front of the car.
Have you thought about maybe a 205/50/17? It would fit better onto the 7" wheel and also into the wheelwell, plus, it's still be 25" tall.
Dave
Old Jul 30, 2008 | 09:42 PM
Fordication's Avatar
Fordication
I am partial to 16s. I think the 17s thru 19s are a bit oversized.
Old Jul 30, 2008 | 09:47 PM
htwheelz67's Avatar
htwheelz67
I run a 245 45 17 in front and a 275 40 17 out back in my 67 vert, they fit perfect
my 67 http://htwheelz.smugmug.com
Old Jul 30, 2008 | 10:49 PM
68EFIvert's Avatar
68EFIvert
I have 225 45 17's up front and it looks good. I am running 275 35 18's out back without problems. I can say that 285 40's will screw something up if the suspension is lowered a couple inches.
Old Jul 31, 2008 | 07:26 AM
dodgestang's Avatar
dodgestang
ORIGINAL: yellow68
I have run slightly taller in the front than the back (235 45 17 front 255 40 17 rear). While it is small and it is not really perceptable my eye always looked down the side of the car and just picked up something that I couldn't quite put my finger on as not being entire right. When I went to 245 40 17 front and 255 40 17 rear with a different brand this issue went away.
Old Jul 31, 2008 | 01:34 PM
jonward786's Avatar
jonward786
i run 245/45/17 in the back and 225/45/17 in the front...stock drums, no spacers with AR Torq-Thrust IIs 17". Fits perfect
Edit: oh and my car is 68 coupe
Old Jul 31, 2008 | 03:25 PM
yellow68's Avatar
yellow68
I thinks what's being missed here is the fact that wheels have already been purchased. 17x9.5 out back and 17x7 (narrowed from 8") up front. Changing wheel sizes / diameters / offsets, etc. is out of the question.
Stock Bullitt wheels do not fit up front without either hitting the upper control arm or the fender. If you run a 1" spacer, you have fender problems. Without, you have UCA problems. So I'm narrowing stock 8" to 7" to solve the problem.
Out back, the 257/40 on a 9.5is a perfect replacement for the 245/45 on an 8.0. What I don't know is what would be a good replacement up fronton a 7.0" wide wheel. 225/50 seems a bit tall. 225/45 seems short. 215/50 seems a little narrow.
I'm just trying to decide which tire will look right on the front with this narrowed wheel. I'd like it to look the same from the side as the stock Bullitt wheel/tire combo does.
Old Jul 31, 2008 | 08:47 PM
68EFIvert's Avatar
68EFIvert
Here is a picture of my 225/45/17 before paint. It will give you a good idea of how it looks.
Old Jul 31, 2008 | 09:01 PM
1slow67's Avatar
1slow67
ROTM Moderator
ORIGINAL: Fordication
I am with you.
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
musnicki
Sep 23, 2015 07:11 AM
Gary Ugarek
Sep 16, 2015 08:04 AM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
