Backup Lights Not Working FMX
Old Jul 31, 2008 | 09:35 PM
palerider's Avatar
palerider
Default Backup Lights Not Working FMX
Have an FMX trans in my 70 Mach1. Backup lights don't work on the car. On my other 70 it has a C4 and was able to replaceneutral safety switch to get working. Not as fmiliar with FMX - any tips on chasing problem down. thanks
Old Jul 31, 2008 | 10:41 PM
1965fastback's Avatar
1965fastback
Default RE: Backup Lights Not Working FMX
Me either but backup light switch??? Ya i know basic, but thats all I can think of.
Old Aug 1, 2008 | 02:57 PM
jlg2002's Avatar
jlg2002
There's a fuse you can check, else locate the BU light switch (probably on the trans) Locate and jumper around it to see if the lites come on.
Old Aug 1, 2008 | 04:53 PM
urban_cowboy's Avatar
urban_cowboy
Out of the firewall, near the master cylinder, there is a plug with four wires in the connector. Two wires are for your backup lights and two are for the neutral safety switch. I do not have my wiring diagram with me, but a color code diagram will help you locate them. You can jumper that backup light wires to manual check the lights. If they come on, it is probably a switch issue. The switch should be mounted on the tranny and makes contact when the linkage hits it while in reverse. I could tell you exactly on a toploader where to look, but I suggest you trace the wires from the firewall to find the switch.
Old Aug 2, 2008 | 01:28 PM
palerider's Avatar
palerider
Thanks I'll try jumping wires and see what happens. thanks
Old Aug 2, 2008 | 10:33 PM
4reboy's Avatar
4reboy
check your bulbs, the PO of my car put a 1 prong-er in it when its supposed to be 2 and it worked, but eventually melted the plastic and eventually fudged it up and now I need a new one.
Old Aug 2, 2008 | 10:56 PM
palerider's Avatar
palerider
Was the bulbs. Ended up switchng out the sockets with receptacle thatI can now run 1156 bulbs in -$10 and now I have backup lights - woo hoo!!
Old Aug 2, 2008 | 11:04 PM
4reboy's Avatar
4reboy
wait you can switch out the sockets? do tell I could maybe fix my light then without having to buy one. What do you do?
Old Aug 4, 2008 | 10:56 AM
sixpony66's Avatar
sixpony66
Generic socket, silicone sealer, it ain't pretty from the back but it will work til you feel like do'in it right!
djbigskrilla
Sep 20, 2022 01:04 AM
movielover40
Aug 27, 2015 10:13 PM
bigdaddy51200
Aug 19, 2015 05:09 AM
jjwinel78
Aug 17, 2015 03:34 PM
philster0306
Aug 10, 2015 11:33 AM
