ride height
Old Aug 9, 2008 | 04:52 PM
fastbacker's Avatar
fastbacker
Default ride height
Hi, I have a 70 fastback with 14” wheels, my problem is I changed the front springs and it seems that the front end is setting too height. I can see at least 4 inches between the top of tire and the fender well opening. Can someone tell me the proper height from the top of fender to the ground? I got the springs from NPD and they said that they were rated for a 302 with A/C but it doesn’t appear so. If someone knows what spring I could order I would very much appreciate it.
70 fastback
302
a/c
Old Aug 9, 2008 | 04:55 PM
1965fastback's Avatar
1965fastback
Default RE: ride height
Theyshould return to stock height after they are broken in. At least that's the conclusion Iv'e drawn from reading several other posts.
Old Aug 9, 2008 | 05:24 PM
1slow67's Avatar
1slow67
ROTM Moderator
It takes a little bit for the springs to break in. So it will sit high and slowly go back down as they get broken in.
Old Aug 9, 2008 | 06:32 PM
Nick.Simonds's Avatar
Nick.Simonds
I would imagine that your old ones where sagging too, so the new ones look higher. Along with the break in period.
Old Aug 9, 2008 | 07:35 PM
71stang99's Avatar
71stang99
On my 72 the front height for driver is 25 3/4 and the passenger is 26. I replaced the springs and shocks along with all of suspension hardware last fall. The car has not been on the road much so I dont know if the springs will 'break' in while its sitting in the garage but it seems lower just from driving impressions then last December when I drove it.
They were supposed to be stock spring rates and at first the car looked front high and this was with a 1" lift for the rear springs, I did not like the *** sag look on the Mach I.
Coyote_hpr
Nov 12, 2019 12:44 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
1Bad71
Sep 30, 2015 07:37 PM
treesloth
Sep 28, 2015 07:03 AM
Sep 27, 2015 03:16 PM
