After market shifter
Old Aug 15, 2008 | 11:43 PM
67droptop1's Avatar
67droptop1
Default After market shifter
I am thinking of correcting my shifting problems by buying an after market shifter. Any suggestions I am thinking B&M Star shifter? No console.
Old Aug 16, 2008 | 09:26 AM
Starfury's Avatar
Starfury
I'm assuming you have a manual since you have 'shifting problems.' What problems? There's nothing drastically wrong with a properly working stock shifter. If your problem is a loose feel and rattling, you may want to try to rebuild your stock shifter first. It's cheap, very easy, and usually tightens up the shifter a fair amount. If your problem is not being able to get in and out of gears properly, you probably need to readjust the linkage.
Old Aug 16, 2008 | 12:15 PM
rst08tierney's Avatar
rst08tierney
what would you need for a rebuild? Sometimes when I throw my car in reverse it will shake like crazy until I make sure its locked in the right gear. It only happens sometimes when I back down driveways with an incline so I was just going to leave it, but if its easy im all over it!
Old Aug 16, 2008 | 03:34 PM
Starfury's Avatar
Starfury
When does it shake? While you're letting out the clutch? While you're backing up?
Old Aug 16, 2008 | 03:56 PM
greystallion66's Avatar
greystallion66
The b&m star shifter is for an automatic. I have had friends that used this shifter because it is a ratchet style and you can "manually" bang through the gears. If you do decide to use this shifter I would go for the shorter base model. Not the standard height model. I think the tall base plate model sits too high. That is just a personal preference though.
Old Aug 16, 2008 | 11:02 PM
67droptop1's Avatar
67droptop1
Ok I should have been more clear I don't have shifting problems I have a linkage problem. It is an automatic. the Tranny and the shifter don't "line" up. So I am thinking of installing a custom one because of this. They use a cable instead of a linkage rod.
firehorse02
Nov 16, 2015 11:28 AM
flash_xx
Oct 16, 2015 07:23 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
