Problems Starting '69 302
Old Aug 16, 2008 | 03:32 PM
REAVER117's Avatar
REAVER117
Default Problems Starting '69 302
I just finished installing a new Edelbrock Performer RPM intake and 1406 600CFM carb on my 302, when I turn the key the engine cranks fine but doesn't start up at all. I've checked the spark plugs and they're bone dry. I get a spark when cranking, but it looks yellow and weak. I have an Pertronix Ignitor II and Flamethrower II coil and I don't have the inline fuel filter connected because I'm waiting on a new filter element. Also the electric choke is not plugged in because I'm not sure where I'm gonna connect it. Any ideas where to start? I've checked the grounds and I'm charging the battery right now but maybe someone has an idea about what's going on.
Old Aug 16, 2008 | 04:20 PM
Gun Jam's Avatar
Gun Jam
I dont think your getting fuel to the carb.
check for a large air leak in the fuel lines at the carb and the pump. Are the lines backwards?
Remove the fuel line from the carb inlet and put it in a glass jar. Crank the engine for 4 seconds. Is the jar full?
-Gun
Old Aug 16, 2008 | 04:39 PM
REAVER117's Avatar
REAVER117
Yeah, I think it was a vacuum leak, I've got it idling fine now, but when I accelerate the RPMs jump to about 3200 and it just sits there until I turn the engine off. Any ideas?
Old Aug 16, 2008 | 08:15 PM
Gun Jam's Avatar
Gun Jam
choke high idle not set properly....even though its disconnected it still will activate the high idle which will stay high as the choke is not hooked up.
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
mustangfan305
Aug 7, 2015 11:09 AM
