i6 to v8
Old Aug 20, 2008 | 08:57 AM
67stangr's Avatar
67stangr
Default i6 to v8
im in the middle of a i6 to v8 on my 67 coupe, and am slowly getting frustrated with it. If anyone has pictures or some words of encouragement it would be helpful, i also love the car and would like to get it on the road thanks
Old Aug 20, 2008 | 09:08 AM
Adrenolin's Avatar
Adrenolin
Its a huge job but CAN BE DONE! I haven't done it myself but there are a few here who have. Keep up with it and get it finished as the feeling of accomplishment you'll have will be overwhelming. Good luck.
At what stage are you currently at? Give some info as to the problems your encountering and perhaps a few pics. Others may be able to give you some assistance from that point.
Old Aug 20, 2008 | 12:39 PM
kalli's Avatar
kalli
bought a car that was 6cyl with engine converted to 8cyl.
drove the **** out of drivetrain for two years and had to do the rest
gearbox, discbrakes (spindles), rear axle
It took about 50 of my best curses and hammerthrowing. I enjoyed parts of it and parts just completely annoyed the crap out of me. I got it finished 2 weeks ago and now watch me smile :-D
Old Aug 20, 2008 | 12:49 PM
eZ's Avatar
eZ
My 65 had an i6 in it 2 years ago...words of encoutagment...its all worth it the first time you start the new motor!
Old Aug 20, 2008 | 02:08 PM
JMD's Avatar
JMD
Where are you stuck right now?
We did a swap on the 66 a while back....
As far as encouragement goes, our swap produced a car that is a blast to drive....
It was worth it...
Old Aug 20, 2008 | 08:44 PM
JamesW's Avatar
JamesW
My fastback below is a T code. I've changed it over and love it. The secret is to not let the pressure of finishing get to you. Take a break, walk away for a month. You'll be re-energized again.
Old Aug 21, 2008 | 10:59 AM
crunchyskippy's Avatar
crunchyskippy
I just recently completed my swap after years progress. Let us know where you're hung up, and most likely one of us has already solved that exact problem.
Old Aug 21, 2008 | 09:09 PM
az1966's Avatar
az1966
Default conversion
I gotta I 6 and as I understand , the following mujst go cause of weignt/power ,, front spindles, rear axle ( both to 5 lugs for power changes) possible tranny/drive shaft swap due to bolt patterns and such ,,,,best advise I can say is is to dig in as far as possible BEFORE STARTING to know what needs to be done and saftly at that
Old Aug 22, 2008 | 03:08 AM
67droptop1's Avatar
67droptop1
I am not really sure what "really" needs changed. My car was a 6 converted to an 8 then I bought it in parts. They did not change the spindles or rearend. or any steering parts as far as I can tell. I think ....and I don't know this for sure but, it would seem logical that the type of driving you paln on doing would dictate alot of you need to be done right away mods. I think I still have the stock coil springs, but it sets fine with a small amount of rake. I think the advice above of not leting the pressure of getting it done right away is really good. I had the same problem. I am now alot calmer about the project it was overwhelming at first. Chang the "have tos" then the "want tos" good luck!!
Old Aug 22, 2008 | 04:05 PM
67stangr's Avatar
67stangr
i am just about to get the engine in the car then get it running, then rear end and all of that stuff. all i want is to get the engine in and running but hard to find time , when i do have time i feel like not doing any thing, since my car and all parts are a few miles away.
