50 ft fat mat
Old Aug 20, 2008 | 11:20 PM
waldo786's Avatar
waldo786
Default 50 ft fat mat
Will the 50 ft of fatmat be enough to do the floors and the inside of my doors on my 66 coupe? I don't need it to be whisper silent, but I did want to try and cut down on some road noise. I don't plan on doing the roof because I did not need to take out my headliner so it is still there. Might do the firewall, but probably wouldn't bother with the trunk - maybe if I had enough. Any suggestions? Will that amount do what I want it to?
Old Aug 20, 2008 | 11:46 PM
Kramer's Avatar
Kramer
i layed 50ft on the floors. it depends on how heavy you go. i have a couple gaps in it, but i also double layered the trans tunnel. i think single layering the trans tunnel could give enough to cover the doors.
Old Aug 21, 2008 | 12:29 AM
4reboy's Avatar
4reboy
good luck getting it on the inside of the doors on a 66, the access holes are very small. The only way to make it semi easy would be if your windows are out then you can drop a full sheet down the window slot
Old Aug 21, 2008 | 09:22 AM
waldo786's Avatar
waldo786
Thanks for the replies and the pic. I had to get new door shells and I was waiting to get some sound deadner before I switched in the window, regulator and all the other stuff, so hopefully it won't be too terribly difficult. I feel like I remember seeing 75 feet being sold before. That would be perfect.
baddog671
Jul 26, 2016 01:20 PM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
MonsterBilly
Sep 19, 2015 08:50 PM
movielover40
Sep 15, 2015 10:37 AM
69FB
Aug 18, 2015 08:50 PM
