power steering
Old Aug 24, 2008 | 10:08 PM
cxr's Avatar
cxr
Default power steering
i know these are 40 something year old cars.... but how well does power steering on a classic mustang compared i dunno to say a modern car?
im just wondering the power steering is a little rough and i am wondering if i need a rebuild or is it just normal for a classic mustang.
not really sure how to describe the roughness.
Old Aug 25, 2008 | 10:38 AM
cxr's Avatar
cxr
i know this questio is generic and not weel asked... buti need info on how well classic mustang power steering should handle to see if mine needs rebuilt or is normal..
THANKS
Old Aug 25, 2008 | 10:55 AM
gjz30075's Avatar
gjz30075
Power steering should feel just like a modern car, maybe even a bit lighter. I had roughness in mine and it turned out to be the steering box needing rebuilding. But the power assist itself was fine.
Old Aug 25, 2008 | 11:10 AM
urban_cowboy's Avatar
urban_cowboy
Rough as in inconsistant, Rough as in hard to turn, Rough as in slack or slop??? The mustang PS is a power assist rather than a power steering gear box so it is going to be a little different than a modern car. It should be pretty smooth if everthing is working correctly though.
Old Aug 25, 2008 | 11:11 AM
wumarshall82's Avatar
wumarshall82
When I turn mine to the left it is very light (seems better than newer cars) but when I turn it to the right it seems a bit harder but not nearly as bad as not having it. Not sure what the issue is there either.. Nothing is leaking but something may need to be rebuilt/replaced. I havent really gotten into it.
Old Aug 25, 2008 | 11:24 AM
paddy187's Avatar
paddy187
Lighter is better (mine is way to light) My has no feeling at all compared with a modern car and there is to much slop. It is on my rebuild list (what isn't)
Old Aug 25, 2008 | 11:52 AM
blue66mustang's Avatar
blue66mustang
There is an adjustment that may fix that. The control valve has an aluminum cap on the end of it. Remove the cap ( it has 2 screws) and you can balance the pressure with the valve under that cap. By turning it clockwise or counter clockwise. This changes the balance from left to right on the ram. I don't remember which way you turn is but it will be pretty evident when you adjust it and then turn the wheel.
Mine works pretty good when it doesn't leak. On the 1966 model the control valve is part of the cross link from the pitman arm and the steering box.
Retails at about $400.00 US. I have replaced 2 of them so far…..
Old Aug 25, 2008 | 08:21 PM
wumarshall82
Thanks for the info. I'll check that out.
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
