Choosing A Harmonic Balancer!?!
Old Aug 30, 2008 | 06:18 PM
juansp67's Avatar
juansp67
Default Choosing A Harmonic Balancer!?!
As im rebuilding my 289 i noticed that the Harmonic Balancer is worn out and i need a new one.
There is two; a stock harmonic balancer and a Harmonic Balancer Romac.
Which is better for the engine i have build so far!?!
here are the pics:
NonStock
http://www.mustangunlimited.com/item...sp?T1=CA225+01
Stock
http://www.mustangunlimited.com/item...p?T1=26316B+01
68,289,RPM CamShaft, stock heads(getting the rpm heads in the future),
RPM Manifold,4Brrl 650 CFM Edelbrock Carb, Hooker Headers, Flowmasters.
Old Aug 30, 2008 | 08:17 PM
1sweet65stang's Avatar
1sweet65stang
whatever you want obviously theres a big price difference but putting money out there for something that might work longer is always worth it unless ur gonna restore and sell....which i couldnt imagine doing
Old Aug 30, 2008 | 08:38 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
good non stock hipo piece http://www.jegs.com/p/Fluidampr/746073/10002/-1/10179
Old Aug 30, 2008 | 08:46 PM
JamesW's Avatar
JamesW
stock one will be fine for your application
Old Aug 30, 2008 | 09:27 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
<---- would spend a few extra $ and buy the streetdampner because there is no rubber outer rind to go bad like stock jmho spend a little more and save in the long run if you plan on keeping her
Old Aug 30, 2008 | 09:56 PM
juansp67's Avatar
juansp67
Originally Posted by rmodel65
The Harmonic FluidDmpr is a 3 bolt and the one you mentioned is a four bolt.
I do plan on keeping the car but the price is a huge jump from the stock does a make a huge difference in power?
Old Aug 30, 2008 | 10:14 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
no power diff. really, but it will help the engine run smoother
Old Aug 30, 2008 | 11:31 PM
MonsterBilly's Avatar
MonsterBilly
I bought a "Powerforce" brand when i needed to replace mine. It was about $109 from Lopers Performance. they do have a mail order portion of the business. it is based in Phoenix,AZ.
the manufacturer also has a website. www.professional-products.com
it was a nice product and came with timing marks for 3 different small block fords.
Old Aug 31, 2008 | 12:50 AM
Starfury's Avatar
Starfury
I have a powerforce as well, and I'm fairly happy with it. It would work great for your application.
Old Aug 31, 2008 | 01:36 PM
juansp67's Avatar
juansp67
The Power force im looking at PT.NO 80006 cost $67.25 and is cheaper than the stock then they have the same one but in Highly Polished Stainless Steel PT.No 82006 for $304.95.
Which power force did u guys buy??
http://www.professional-products.com...ductSBford.php
Here are the Links where i seeing the prices:
80006-
http://www.cnc-motorsports.com/produ...ID=8041&CtgID=
82006-
http://www.outperformanceshop.com/pr.../prp-82006.htm
