no reverse
Old Sep 3, 2008 | 08:54 PM
kgmunro's Avatar
kgmunro
Default no reverse
Hi everyone I am in need of some help. I put an engine in a friends 1973
convertible stang and have a reverse problem. It is a 351c w/4 speed manual. I can not shift the car into reverse. Can this be due to a reverse lockout adjustment. How can I figure how to adjust it? All 4 forward gears are fine, but will not slide over left into reverse?
Old Sep 3, 2008 | 10:54 PM
Toddman0025's Avatar
Toddman0025
When i first got my 351c it took me 25min to get the damn thing into reverse, it's a tough spot to locate and seems like there's about a centimeter of play for getting it into gear. I'm interested to hear possible culprits though...
Old Sep 4, 2008 | 02:58 AM
Starfury's Avatar
Starfury
Well, does it just not slide into reverse, or does it grind?
Assuming it's not grinding, I'd start by readjusting the shift linkage. Instructions can be found in the factory shop manual. Reverse uses its own linkage, so it could just be the linkage is out of adjustment.
Old Sep 4, 2008 | 05:01 AM
kalli's Avatar
kalli
aye. I have 2.50$ on this bet as well. Can't think of anything else.
Kalli
Old Sep 4, 2008 | 06:43 AM
kgmunro's Avatar
kgmunro
Default reverse adjust
pretty sure you guys are right. the engine and trans were not installed when i got the car. is it the linkage that goes from the shifter up to the column linkage rod? there is a bolt/slide adjustment there that i just bolted in the middle to start.
Old Sep 4, 2008 | 11:15 AM
Starfury's Avatar
Starfury
Column? I wasn't aware there were any column-shifted manual Mustangs...
Old Sep 4, 2008 | 03:58 PM
kgmunro's Avatar
kgmunro
no no you misunderstand me. the one rod goes to the column from the shifter under the car...in the engine bay.
Old Sep 4, 2008 | 09:13 PM
kgmunro's Avatar
kgmunro
hey guys that is all I needed to do. I adjusted the slide on the shift arm to the lower column and voila...reverse. thanks for the posts.
Old Sep 4, 2008 | 09:26 PM
rlovering's Avatar
rlovering
dayem, got some smart peeps here. I'm sure to ask any of my questions here!
Old Sep 4, 2008 | 09:47 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
It won't hurt to still adjust the linkage according to the shop manual. It might prevent the linkage from locking up down the road.
