Recommended jetting?
Old Sep 5, 2008 | 09:26 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default Recommended jetting?
My friend has a 68 coupe with a 302 out of a 72 Maverick. His uncle told him is jets were too big for the engine. He has a 4v holley with 350 main jets. Are those too big? I'm trying to help him.
Old Sep 5, 2008 | 11:12 PM
racin66coupe's Avatar
racin66coupe
hows it running? if its rich the jets may be to big. what are 350 main jets?
Old Sep 5, 2008 | 11:26 PM
jwog666's Avatar
jwog666
take it for a good beat run, then pull a plug, dark=rich, tan=perfect, white=lean. and go from there. this is assuming that the accelerator pump and power valve are correct and working properly.
Old Sep 5, 2008 | 11:48 PM
67mustang302's Avatar
67mustang302
Rich where? Idle, part throttle cruise, part throttle acceleration, WOT? And there are no 350 jets.
Old Sep 6, 2008 | 10:38 AM
1slow67's Avatar
1slow67
ROTM Moderator
Last time I looked his jets were in the 300s size wise. His uncle told him those were too big for his car.
Old Sep 6, 2008 | 11:45 AM
67mustang302
Holleys don't have jets that big. The biggest alcohol jet they make is a .200. Maybe it's an old numbering system they don't use any more.
Old Sep 7, 2008 | 12:01 AM
silverblue66's Avatar
silverblue66
I have a mild 289 with a 4bbl holley and I have number (main) 64 jets and they are just a touch on the rich side. number 62s are just a touch on the lean side. bet you can guess what jets I'm putting in next. 64s are a good place to start as they come on most out of the box street holleys but tend to be a little bit rich. I have no idea what a 350 jet is, but I know Holly jets corrrepond roughly to the drill size. i.e. a 64 jet is .064" in diameter. this doesn't always hold true because they are actually numbered based on flow not diameter. for a stock to mild 302 the jetting should be VERY close to what I have. to fine tune the jetting at cruse you can use a vacuum guage fixed in the car with you. adjust jets fr highest vacuume. then put fresh sparkplugs in the car, cruse for a mile or so then shut the car off while crusing. coast to a stop and check the color of the porcelen. it should be a light grey to tan. darker is to rich. white is too lean andbad fr your engine!!! hope this info helps.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
UrS4
Sep 30, 2015 10:13 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
