Timing Help
8 degress is factory setting. in any case all recommendations usually go:
advance as much as possible without pinging. So it's basically adjust-drive-adjust-drive
8 deg should be fine in all cases.
If your car doesn't idle nicely it can be:
- lopey (mad camshaft) ?
- you didn't plug all ports on the carburator and it's sucking air where it shouldn't
- you have hooked up the vacuum of distributor to manifold vacuum instead of ported vacuum
etc etc etc
in any case it should run smooth at 8 degree idle. use it as a basline
etc etc etc
mungodrums
Oct 7, 2015 04:01 AM
Sep 8, 2015 11:50 AM
