351 w build
Old Sep 7, 2008 | 09:28 PM
boss_dude_429's Avatar
boss_dude_429
Default 351 w build
ok here it is i have ordered the 427 stroker kit, on it's way, the cam shaft specs are as follows
SOLID ROLLER
DURATION: 273/279
DURATION @ .050: 243/249
LIFT: 616/ 624
now for the blower, which will come soon, it will be from Hampton blowers
my only problem is what heads to use, i REALLY REALLY want to use the AFD SP4VR (245 cc) cleveland style heads, the only thing about it though is that i recall that, though the heads will bolt to the block wasn't there something about the water jackets different or something like this, anyway this is a pretty big deal so so input quick like would be greatly appreciated!!!!! =)
Old Sep 7, 2008 | 10:20 PM
69mach1377's Avatar
69mach1377
C style heads need to have some ports blocked and the W block needs 3 holes added on each bank. Google 'Clevor' to find the details.
Old Sep 8, 2008 | 05:36 PM
boss_dude_429
anyone else!?!?!?!?!
Old Sep 8, 2008 | 07:37 PM
htwheelz67's Avatar
htwheelz67
I'm not sure a 427 kit is the greatest for reliability with a blower, especially in a stock style block. Is that what your plans are? hopefully your using a dart block with a big bore.....sounds like your planning a nasty 700-800hp stroker.
Old Sep 8, 2008 | 09:16 PM
boss_dude_429
=) hehehehehehehehe you have no idea......... actually it's closer to 1200hp with the go-go good gas, i'm using an all aluminum block that a friend, who just happens to be a machinist, is building just for me!!!!! anyway what do you think about the heads??? that was my big question my goal is to beat this car, i think a lenco would go nicely behind this lil' monster....anyways this is the ultimate goal....... to decimate the killer camaro below...... then my lil' monster will be on top, o yea this dude spanked every one of my friends so some payback is in order seeings how we only use fords
bad camaro
Old Sep 8, 2008 | 09:43 PM
Celtic37's Avatar
Celtic37
You beat that Bow-Tie and you my friend will be a god. People will bow at your feet.
Old Sep 9, 2008 | 06:42 PM
69mach1377's Avatar
69mach1377
You will also need a very special intake to mate C heads to a W block.
Old Sep 9, 2008 | 06:49 PM
racin66coupe's Avatar
racin66coupe
edelbrock now makes a clevor intake
Old Sep 9, 2008 | 07:22 PM
my77stang's Avatar
my77stang
and i believe the heads your talking about are already machined to work on the 302/351w heads
Old Sep 9, 2008 | 11:00 PM
htwheelz67's Avatar
htwheelz67
sounds like some Yates heads are in order.........
