How to identify whether it is a "REAL" GT ?
Old Sep 11, 2008 | 11:38 PM
thaimustang's Avatar
thaimustang
Default How to identify whether it is a "REAL" GT ?
Hello,
How can i identify whether a 66 mustang fastback a real gt or not???
Anyone have a good tip or goot website ???
Thanks...
Old Sep 12, 2008 | 01:51 AM
Stepman's Avatar
Stepman
Look for the "body buck tag". It will list options to be put on the car. Guess they were put in different locations thru the years. Some on the top edge of fenders, some on the core support..near the right? headlight? It's a credit card size piece of sheet metal looking thingy.
Old Sep 12, 2008 | 02:06 AM
sethalot's Avatar
sethalot
for the 66 GT handling package the car must have a A-code 289 4V, the grille is the same as a 65 GT with the blacked out screen and fog lights, and it should have a GT badge and individually lettered m u s t a n g in a stripe on the doors, im sure there is more but is 2:05 in the morning and im not gonna look anymore up hope it helps
Old Sep 12, 2008 | 07:16 AM
chillininnh's Avatar
chillininnh
This site should help.
http://www.karmustang.com/factory_gts.php
Old Sep 12, 2008 | 09:49 AM
ky's Avatar
ky
America ftw
look for a hole in the radiator support for the fog light wiring. and stick your finger through the hole in the subframe right next to the rear leaf spring mount, there should be a plate which is proof it had dual exhaust, which ALL gts did.
but just cause it has those 2 doesnt mean its a gt, theyre only REALLY good clues. the real way is to check the vin. theres 3 stamped on the inner fender aprons.
Old Sep 12, 2008 | 10:27 AM
fast65's Avatar
fast65
The only way you can really tell it's an actual GT is if you have the window sticker. But if it has all of the things listed above, especially if the holes in the radiator support are punched not drilled and if it has that hole in the subframe then you can be pretty sure it's a real GT car.
Old Sep 12, 2008 | 10:43 AM
voipguy's Avatar
voipguy
checkout this article:
http://www.mustangmonthly.com/howto/30040/index.html
Old Sep 12, 2008 | 11:01 AM
Starfury's Avatar
Starfury
The VIN doesn't tell you whether or not it's a GT. 67-73 models can get a Marti report, but the 65-66 documentation has been lost, so you need to stick with physical verification procedures.
Old Sep 12, 2008 | 11:23 AM
urban_cowboy's Avatar
urban_cowboy
Only the Metuchen plant used buck/body tags in 66. The others started using them in 68. I am pretty sure they did not notate the GT package on the plate until 68. Marti may have some records to go by, but I do not think the body tag is going to help you.
Old Sep 12, 2008 | 12:18 PM
Stepman's Avatar
Stepman
I did not know that. Learn something new every day. Guess I'm done for today then.
