Need Some Help
Old Sep 16, 2008 | 09:26 AM
71cougar351's Avatar
71cougar351
Question Need Some Help
Hello,
First off I would like to say hello to everyone. Now to get to business. I have a 71 Cougar with a 351c 2v (if you could not guess from the name). When I drive the car everything seems smooth until I stop. When I accelerate the car hesitates for a sec or 2 and then goes. Any ideas what could be causing this? I cleaned the carb, checked adjustments, that sorta thing. Am I gonna need a new carb you think? Thanks in advance for any input.
Old Sep 16, 2008 | 09:34 AM
kalli's Avatar
kalli
do you mean the engine would not rev up (hesitate) or do you mean the engine sounds okish, but the car does not move for 1 sec or 2 ?
in the first case check for timing as well as the accelerator pump setup
in the latter case the problem is rather related to automatic gearbox
Old Sep 16, 2008 | 09:41 AM
lunarweasel's Avatar
lunarweasel
My Uncle has a 71 351 Cougar, cool car.
Old Sep 16, 2008 | 09:51 AM
71cougar351
the engine sounds good, every now and then when i stop, then go it hesitates. You press the gas and the car acts like it is gonna stall for a split second then goes fine. It happens when you go from a low speed and start accelerating, like when I slow down to turn or stop at a light.
Old Sep 16, 2008 | 03:32 PM
jlg2002's Avatar
jlg2002
Carb is in need of an overhaul ( accel pump) or you have a plugged fuel filter.
