358 vs 408
Old Sep 21, 2008 | 10:14 AM
racin66coupe's Avatar
racin66coupe
Default 358 vs 408
i didnt get much responce last time i posted this.. so i figured id try again.
witch would you build? a 358 or 408? how close would the cost be betwen the 2? and wich one would last longer?
Old Sep 21, 2008 | 10:55 AM
.boB's Avatar
.boB
Depends on what your goals are, and what you're starting with. If you need to replace the entire rotating assembly and have the cylinders bored, then costs will be about the same.
If you're building a car that power is more important than anything else, go with the cubes. There's no replacement for displacement; you can't beat cubes.
The down side of more cubes is that it takes more fuel to run. If the rest of the drive line (transmission, driveshaft, diff) is a little weak, you'll be spending more money to upgrade. Depending on the car you're starting with, you might have to upgrade the fuel system; $$$.
As long as you shoose your parts carefully and assemble carefully, longevity will be the same between the two.
Old Sep 21, 2008 | 04:34 PM
racin66coupe
anyone else?
Old Sep 21, 2008 | 06:47 PM
4reboy's Avatar
4reboy
well a 358 would just be a 351 bored to like .03 or .04 over, correct? I think i calculated mine out to a 358 or something close.
With that being said if you're just going stock I'd assume that would be cheaper, and would last long since it has shorter rods. However if you are looking for gobs of power, you might as well stroke it for not much more $$$
Old Sep 21, 2008 | 11:14 PM
66JameStang's Avatar
66JameStang
I LOVE MY 408 FTW!!!!!!
I am not sure on the differences in cost or particular power but, I can tell you that having mine is a complete blast. The engine has power and makes the drive completely worth it. The cost can be relatively high for a beefed up 408 but it is only relative to your budget. I know the next engine JMD is building will be a 408.
You would not be disappointed with it... Any real specific questions about the engine itself?
Old Sep 21, 2008 | 11:31 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
if you have the cash go for the 408 stroker
Old Sep 22, 2008 | 01:22 PM
71stang99's Avatar
71stang99
http://www.speedomotive.com/p-610-fo...#KitInPostBack
Anyone know anything about this vendor? Does the price seem right depending on the packages offered?
Thanks
90Mustangfan
Apr 19, 2006 01:45 AM
sntheticdelusion1
Jul 30, 2005 01:07 AM
flamin
Nov 21, 2004 12:02 PM
perfdesign.com
Jun 26, 2004 12:25 AM
MoreCubes
Feb 18, 2003 11:16 AM
