torque converter, starter problems
Old Sep 21, 2008 | 05:00 PM
eep4life's Avatar
eep4life
Default torque converter, starter problems
so i go to bolt up my starter and when i do i realize that the bolts comming off the torque converter that allow you to bolt it to the flywheel are too long and when the engine is going to turn they are going to nick the starter... any possible solutions to this or am i going to have to drop the tranny and replace the torque converter?
Old Sep 21, 2008 | 05:03 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
do you have the block plate installed?
Old Sep 23, 2008 | 03:33 PM
tnyankee's Avatar
tnyankee
Also, make sure that the torque converter is seated all the way into the transmission shaft. I had a problem with a buddies car where it wasn't seated all the way and was binding.
Tony DiMaiolo
Old Sep 25, 2008 | 04:45 PM
eep4life's Avatar
eep4life
ok ill check the torque converter.. im pretty sure its all the way in ( is there a specific way to tell if its all the way in) also im pretty sure its actually my starter... its one of those mini high torque starters... it has a lip on it that protrudes towards the TC and that is what the bolts seem to be hitting. (thats what i get for buying a starter off of ebay) so im gonna go buy a started from autozone or something and see if it fitts right... at least i can always return that one... thanks for the posts guys
Old Sep 25, 2008 | 11:23 PM
eep4life's Avatar
eep4life
Default possible new problems
hey guys.. so i ve been doing some research on line and i keep seeing these diagrams of flywheel assemblys and many of them mention a spacer of some sort? so i was wondering if there is suspose to be a spacer or something behide the flywheel.. i put a pic of a diagram i drew up (please mind my bad drawing) but besides the block plate (lower right coner) is there some thing else that goes behind the flywheel to bolt up to the holes on the back of the block?
http://i197.photobucket.com/albums/a...7/flywheel.jpg
Old Sep 26, 2008 | 12:02 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yes the block plate that i mentioned in the 1st reply :P
its a big metal shim that is sandwiched in between the motor and tranny it must go one before the flexplate
Old Sep 26, 2008 | 12:03 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
similar to this but an auto will have a cut out at the bottom so you can take the torque converter bolts loose http://www.thepartsbin.com/images/pr...wood/15726.jpg
Old Sep 26, 2008 | 02:55 PM
eep4life's Avatar
eep4life
well the block plate is there , however the circular hole in the middle is so wide it does not effect the flywheel. it does put a small space inbetwwen the trans and the block which i can see really helping the distance of the bolt sticking out to much but what i was refering to is this peice which i just found a few days ago... im almost positive that it goes either before or after the flywheel... could you guys give any insight to what this peice is? thanks guys
http://i197.photobucket.com/albums/a...7/IMG_0992.jpg
Old Sep 26, 2008 | 04:43 PM
eep4life's Avatar
eep4life
any one know what that part could be.. does it go between the flywheel and the block? i got under right know and dropped my trans... did it in about 2 hours not to bad since i dont have a trans jack.. anyways.. ill snap some photos and such maybe im missing something/
Old Sep 26, 2008 | 04:52 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the plate goes on before you put the flywheel on and is sandwhiched inbetween the tranny and motor i just took some pics wait a min or 2 and check back
