well this ****es me off
Old Sep 22, 2008 | 06:17 PM
racin66coupe's Avatar
racin66coupe
Default well this ****es me off
so, im outside workin on the stang (FINALLY!!!!!) and i got my trunk dropoff all cut to size and ready to weld in. i get my welder. and.. it isnt working, wtf? os i open the side and realize the freakin wheel that feeds the wire through isnt hitting the wire! any ideas? im takin the welder to the local wending shop and hopefully they can fix it.
/end rant
Old Sep 22, 2008 | 06:46 PM
65rangoon's Avatar
65rangoon
um did you check the tensioner ? there should be a screw the adjust the wheel for the tension.
Old Sep 22, 2008 | 06:52 PM
racin66coupe
huh??
Old Sep 22, 2008 | 07:00 PM
1965fastback's Avatar
1965fastback
Tighten the wire maybe, i dunno.
Old Sep 22, 2008 | 07:03 PM
racin66coupe
i tried everything icould think of, i didnt see any adjustment stuff
Old Sep 22, 2008 | 07:38 PM
Shawnb23's Avatar
Shawnb23
Is it a mig? If so when you click the trigger does your spool rotate? If so then check the tension and make sure the wire is getting fed through the hose. If the spool is turning and the wire isn't being forced in then adjust the tensioner (its a little round thing near where you set your wire to be fed through. If it Isn't being fed through take the nozzle off your gun and check your tip and make sure the wire isn't jammed up their.
Old Sep 22, 2008 | 08:06 PM
racin66coupe
its a lincoln mig/flux
the little wheel that spins, and makes contact with the wire to push it through isnt hitting it. wheres the tensioner?
Old Sep 22, 2008 | 08:07 PM
racin66coupe
here, heres a pic of what isnt hitting http://www.mig-welding.co.uk/wire-fe...er-grooves.jpg
Old Sep 22, 2008 | 08:16 PM
blue66mustang's Avatar
blue66mustang
http://content.lincolnelectric.com/p...ature/e723.pdf
Page 2
Old Sep 22, 2008 | 08:20 PM
racin66coupe
that didnt help...
