Car starts off in second gear?!?
Old Sep 23, 2008 | 10:53 PM
petespokerplanet's Avatar
petespokerplanet
Default Car starts off in second gear?!?
When I put the car in drive, it takes off in second gear. When I manually shift it down, then it takes off in 1st gear.
I know that the kickdown lever is not hooked up right, which I am in the process of replacing, but from what I read it doesn't necessarity have to do with the problem of taking off in first gear
Any suggestions?
Old Sep 23, 2008 | 10:55 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
replace the shifter bushings and adjust the shifters linkage also how is your tranny mounts?
Old Sep 23, 2008 | 11:03 PM
petespokerplanet
I recently did change my shifter bushings, and I'm not sure I did it right because I had to readjust it just to get the car moving.
How would I adjust the shifter linkage, ie. do I need to make sure it's pushed one way or another, or something like that?
I don't know about the tranny mounts, I'll have to check them later.
Old Sep 23, 2008 | 11:15 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
there is a bushing on the tranny side of the linkage iirc and the mount or even a motor mount can be bad causing problems sine it could be pulling on the linkage because of the mount being worn
Old Sep 23, 2008 | 11:20 PM
ky's Avatar
ky
America ftw
what year car?
depending on what year, you might have the shift pattern wrong. on a 66, theres 2 dots. one plain one and one with a green dot. the green dot is DRIVE. the plain white dot is only 2nd and 3rd. (for whatever reason, i think its for rain).
Old Sep 23, 2008 | 11:24 PM
Starfury's Avatar
Starfury
A lot of people confuse the two. And yes, the 1st gear lockout makes it easier to drive in the rain without spinning a tire.
petespokerplanet
Originally Posted by true66gt
what year car?
Mine's a 65. That could be a possibility because I changed out the shifter cover. Is the green dot position next to neutral or two after?
Old Sep 24, 2008 | 12:23 AM
ky's Avatar
ky
America ftw
green dot is 2 DOWN FROM N. which is 1 ABOVE LOW (1st)
Old Sep 24, 2008 | 12:38 AM
petespokerplanet
THAT WOULD EXPLAIN EVERYTHING!!!!!
Hopefully that is what it is and there is no problem. So now I can waste my money fixin something else.
So the correct order is PRN(2nd)(Drive)L.
I couldn't find this info anywhere. Thanks.
Old Sep 24, 2008 | 12:41 AM
ky's Avatar
ky
America ftw
yes that is correct man. and in 67 it changed to PRND21. which is what someone had put in my 66. but now i just picked my tranny back up cause i had it rebuilt for a full manual reverse valve body.
