exhaust kit
Old Sep 27, 2008 | 04:44 PM
  #21
ky's Avatar
ky
America ftw
why stainless steel piping?
aluminized is probably less than half the price and will last almost as long.
Old Sep 28, 2008 | 01:05 AM
  #22
photocliff's Avatar
photocliff
What type of metal pipes are the new auto manufacturers putting on their cars. My 96 Ranger mufflers and pipes still look pretty good I know they are original because I bought it new.
Old Sep 28, 2008 | 01:08 AM
  #23
Starfury's Avatar
Starfury
Most pipes are aluminized, because it's cheap and fairly durable. Stainless looks nice, but it's hard to weld and is expensive.
Old Sep 28, 2008 | 08:29 AM
  #24
fakesnakes's Avatar
fakesnakes
I guess I have a slightly different perspective. While there are advantages and disadvantages to the "bolt in" systems vs. shop installed, one of the bigest disadvantages of the shop installed is that it is not mandrel bent pipe. Take a look at the bends, particularly those that go over the rear axle. The bender collapses the pipe, often making 2 1/4" pipe act more like 1 3/4" pipe. Also, you really need a crossover pipe. An x-pipe crossover is much more efficient than an h-pipe at scavenging exhaust gases. Most shops can probably do an h-pipe if pushed, but not an x-pipe. You can also install a kit, they actually do fit well if you spend some time, and then have the system tacked by a shop with a tig welder. If you've spent any money on performance upgrades (heads, cam, induction, etc.), you can give it all away with a poor flowing exhaust. For most stock set ups, 2 1/4" mandrel bent with an x-pipe or even an h-pipe is fine, in fact here is a good one:
http://store.summitracing.com/partde...5&autoview=sku
For me, I have a 450hp (flywheel) boss 347 going into my 1966 fastback and I am using this system:
Old Sep 28, 2008 | 09:17 AM
  #25
arthur's Avatar
arthur
i definitly wants the magnaflow so that first one is out of the question cause of the flowmaster mufflers.
i had that second one in mind ( http://store.summitracing.com/partde...5&autoview=sku ) though they only come in 2.5 inch.
so now i consider buying the mufflers and x-pipe and find someone here who is willing to to make an exhaust system using my own parts.
arthur
Old Sep 28, 2008 | 09:45 AM
  #26
LCC's Avatar
LCC
2 1/4 will be fine, 2 1/2 would max for your application.
Stainless is what I like using, you do it once and always looks good. And for mufflers, Flowmasters baby...
Granatelli Sales
Mar 25, 2016 08:01 PM
Sep 10, 2015 08:39 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
TimeLord101
Sep 4, 2015 09:27 AM
