Wheels and tires
Old Sep 28, 2008 | 08:59 AM
fakesnakes's Avatar
fakesnakes
Default Wheels and tires
Yes, I searched and searched, so please don't skewer me too bad.
Recommend a 17" tire and size for my 1966 fastback. I need tread, so width is important (that's what she said), but I have to steer so it has to fit in the stock wheel wells. Should I go with a different size front and rear?
I did find this which is helpful:
http://www.mustangmonthly.com/techar...fit/index.html
Old Sep 28, 2008 | 10:19 AM
Starfury's Avatar
Starfury
I'd recommend either BFG G-Force tires, or a set of Goodyear Eagle F1 GS-D3's. If you want something that will last a little longer but still grab well, G-Force Sports. If you want something that will stick to the road, G-Force KDW's or the F1 GS-D3's (stick better, shorter life).
Old Sep 28, 2008 | 06:23 PM
Iskwezm's Avatar
Iskwezm
your tire size wheel depend on the amount its lowered.IMO, I wouldnt do the same size as somebody else unless you have the exact same drop as them .
Old Sep 28, 2008 | 07:03 PM
Carlos Pineiro's Avatar
Carlos Pineiro
+1
Also, if your front tires are wider than stock, or if the wheel offset causes the track to be wider, you might clear your rubber on a level road, but hit your wheel wells on bumps or turns or even slowly backing out of a driveway while turning. This can be really inconvenient if it's a daily driver.
Handling, response, acceleration, braking, steering and even shifting will be different with larger wheels/tires. If you drive the car a lot, consider all that stuff.
Good Luck,
CP
Old Sep 28, 2008 | 07:14 PM
Norm Peterson's Avatar
Norm Peterson
Track down Dodgestang's wheel & tire page for this very topic.
http://www.dodgestang.com/mustang.htm
Norm
Old Sep 28, 2008 | 08:59 PM
fakesnakes's Avatar
fakesnakes
Norm, that chart is awesome! Thanks so much.
Old Sep 28, 2008 | 09:47 PM
andrewmp6's Avatar
andrewmp6
Yeah i always run the same size front and back easy to rotate later on.
robcy
Suspension
Oct 27, 2015 11:14 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
Oct 7, 2015 07:02 PM
mungodrums
Sep 28, 2015 05:45 AM
Sep 8, 2015 11:50 AM
