Bad Judgement???
Old Oct 2, 2008 | 04:51 PM
unit91's Avatar
unit91
Angry Bad Judgement???
I sprayed the underside of the hood with undercoating and it is still tacky after a couple of days. Did I screw up in using undercoating? A mechanic told me to use it because it would deaden sound as well as keeping the hood from rusting. ?????
Old Oct 2, 2008 | 05:21 PM
RobertJ's Avatar
RobertJ
You used it out of a spray bomb? I wouldn't spray that crap anywhere on any car I own. When I restored my '69 Firebird I used professional grade in the rear fender wells, and it came out really nice. If you decide you don't want that stuff there anymore you're going to have a heck of a time removing it. Unless you park your car outside, hoods are really very likely to rust anyway. IMO, yes, you used bad judgement.
Old Oct 2, 2008 | 05:30 PM
Shawnb23's Avatar
Shawnb23
That stuff is nasty, but it should dry.
Old Oct 2, 2008 | 06:09 PM
HGC's Avatar
HGC
Maybe you just put it on a little thick. I agree it should dry. Rubberized undercoating can feel like it is tacky when in fact it is just the soft nature of the product. Leave it parked with the hood up for a few days.
Old Oct 2, 2008 | 06:10 PM
cprstreetmachines's Avatar
cprstreetmachines
Check to see if it's tacky before the engine runs. the heat may cause it to tack up after the engine runs.
Old Oct 2, 2008 | 07:01 PM
unit91's Avatar
unit91
I don't know if it's rubberized, but it is petroleum based. Used by the military.
Old Oct 2, 2008 | 08:35 PM
HGC's Avatar
HGC
Almost everything is petroleum based. It should say on the instructions/can/whatever if it is rubberized.
Old Oct 2, 2008 | 10:23 PM
unit91's Avatar
unit91
If this crap never dries, what will remove it?
Old Oct 2, 2008 | 10:51 PM
valley firearms's Avatar
valley firearms
Chemicals! I hope you don't have an engine fire with that stuff under there. I think bed liner would have been better. Take the hood off and pressure wash it. That may remove most of the undercoating. You may have to use acetone to break up the rest. Is the paint on top good? If it is be careful with the chemicals.
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
UrS4
Sep 30, 2015 10:13 AM
GLOCKer
Sep 28, 2015 07:36 AM
