Spark plugs?
Old May 22, 2005 | 12:22 PM
6mustang6's Avatar
6mustang6
Default Spark plugs?
I want to put Bosch Platinum 4's in my 66 289. THey dont have them for that engine, but they have them for a 1983 302.
Are they interchangable? Thanks
Old May 22, 2005 | 01:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Spark plugs?
Well, according to the chart I have, Bosch didn't make the platinum 4 for vintage 289's. It wasn't until the 1983 5.0L that they offered that plug. On the other hand, NGK has a platinum plug for your 289. The part number is WR 5GP. Here is a pic.
Old May 22, 2005 | 02:04 PM
6mustang6's Avatar
6mustang6
Is that plug as good as the platinum 4? I put the P4's in my impala[ i know it's a chevrolet dont rag me] and it ran much better. So the 1983 5.0 plugs wouldn't fit?
Old May 22, 2005 | 02:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
Oh, they will probably fit, but I don't have that information. Maybe some of the other members can chime in here. However, the NGK plugs are extremely good plugs. I use the stock Motorcraft plugs that work just fine. I also have a Motorcraft carb, etc. But, I am one of those old original type guys, so don't be swayed by what I say.
Old May 22, 2005 | 02:32 PM
6mustang6's Avatar
6mustang6
yeah, I just don't want to spend $6.00 a plug and they not fit. i'll look at the Ngk plugs, i'll probably get them. Have you tried that pertronix ignitor 2 electronic igintion thing? It converts your points to an electronic ignition. Im thinking of getting that.
Old May 22, 2005 | 02:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah I have the Pertronix set-up. Be sure to also get the coil. With them both, you can open up those NGK's to .040 or so. Hellava hot spark.
Old May 22, 2005 | 02:39 PM
6mustang6's Avatar
6mustang6
Did you feel the difference, in the performance area? I was planning on getting the coil, because right now i have the original yellow top on there.
Old May 22, 2005 | 02:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
Oh yeah....the electronic ignition is far superior to the points and condenser. However, I still have a set of points in my glove box. I have heard stories about the pertronix failing, so I just want the insurance of having the original points and condenser just in case I am on a lonely road at night and that sucker fails. I also keep a full set of tools in my trunk.
Old May 22, 2005 | 02:55 PM
6mustang6's Avatar
6mustang6
HAHAHa, thanks for telling me that. I might want to keep a set too. Im going to be getting it in a couple of days. Im going to get the higher performance one for $105. They say it gets more spark.
Old May 22, 2005 | 03:14 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, the flamethrower puts out 40,000 volts, and the flamethrower II puts out 45,000 volts.
