H.I.D. Headlights
Old Oct 9, 2008 | 03:38 PM
pimp2303's Avatar
pimp2303
Default H.I.D. Headlights
Anyone here have HID's on there classic mustangs. if so what kit did you buy, and do you have a picture of what it looks like.
Old Oct 9, 2008 | 06:51 PM
Nabster's Avatar
Nabster
Just keep in mind if you decide to upgrade to them you really should replace all the wiring for the headlight circuit, HIDs draw more amps than the stock stuff during startup before they settle down.
Old Oct 9, 2008 | 09:22 PM
pimp2303's Avatar
pimp2303
when you say replace, do you mean put stronger wire or just put new wires.
Old Oct 9, 2008 | 10:31 PM
guybored's Avatar
guybored
I would think thicker wire and add some relays in there. If you do install HID post some pics. Would like to know what you use since I have been thinking of doing the same thing.
Old Oct 10, 2008 | 09:26 AM
Adrenolin's Avatar
Adrenolin
We're leaning towards this also though it'll be next spring before I'll be at that point so haven't looked into it yet.
Old Oct 10, 2008 | 10:30 AM
Iskwezm's Avatar
Iskwezm
If you get a cheap set of HID's, they get their power from the headlight plug. A good set of HID's will have its own power wire to the battery and use the headlight plug for a trigger.The relays and ballast step up the power.
Old Oct 10, 2008 | 11:17 AM
Starfury's Avatar
Starfury
It's not hard to wire your own relays in for the headlight circuit.
Old Oct 10, 2008 | 02:02 PM
tyler72's Avatar
tyler72
+1 It would be really easy to add in a couple relays to keep from burning up the factory wiring. You just use the factory stuff as the trigger wires to turn the relays on.
Old Oct 10, 2008 | 09:09 PM
pimp2303's Avatar
pimp2303
so no one has any pictures of what HID would look like on a classic mustang. i want to see how it will look before i actually do it.
Old Oct 11, 2008 | 01:05 AM
petespokerplanet's Avatar
petespokerplanet
Default Glad you asked, love em.
I installed 6000K HIDs for around $100.00 with bulbs and projector housing. LOVE them. The only problem is that you will either have to buy bi-zenon, because you will not be able to have hi-beams in the same bulb. The HID bi-zenon usually have a secondary bulb glued into the projector to use as high beams. Or, you could go without hi-beams or wire them into your fog lamps.
If you're worried about wiring, then like someone said earlier, most places that sell the HIDs offer an additional wiring harness to hook directly to the battery for about ten dollars.
I got the HIDs and then the sequential LEDs in back, they both look awesome.
PS. Make sure you are aware of the highbeam switch, because when the switch is on, the headlights will be off.
