BB toploader?
Old Oct 20, 2008 | 01:31 PM
racin66coupe's Avatar
racin66coupe
Default BB toploader?
can i run a BB toploader on a SB? i feel like ive heard the input shaft is different? also, would a toploader 3spd bellhousing work?
Old Oct 20, 2008 | 01:49 PM
Starfury's Avatar
Starfury
Yes, the input shaft is slightly shorter. I believe Glazier's Mustang Barn sells an extended pilot bushing for this specific purpose, however, and it should work fine with that 3sp toplaoder bellhousing.
Old Oct 20, 2008 | 05:49 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
You can also buy the proper shaft. Installation requires TOTAL dismantling of the tranny, but it's not that hard and it isn't a bad idea to go ahead and rebuild the thing while it's out.
Old Oct 20, 2008 | 07:06 PM
racin66coupe
how important is it to have the tailhousing from that car? as im getting a custom driveshaft mostlikely anyways... and it seems that it is the right tail housing
Old Oct 20, 2008 | 07:50 PM
Starfury's Avatar
Starfury
The tailhousing is specific to Mustangs, so you absolutely need it. why wouldn't you get it with the rest of the tranny?
Old Oct 20, 2008 | 08:06 PM
racin66coupe
huh?? it does come with a tailhousing, the tag he gave me was from a 64 galaxie 390? how hard would it be to replace the tail housing?
Old Oct 21, 2008 | 01:01 AM
Starfury's Avatar
Starfury
Oh....gotcha. You didn't explain that:P
No, the tailhousing is not correct. The shifter mount on the Mustang tailhousings are on the far rear, whereas the Galaxie tailhousing is going to have the shifter mounted more towards the middle or front of the tailhousing. That said, it's not difficult to swap tailhousings if you happen to have one lying around.
Old Oct 21, 2008 | 06:45 AM
racin66coupe
hmm... could i make a custom bracket maybe to mount the shifter to?i dont see how that souldnt work? or maybe id just get the right tailhousing lol
Old Oct 21, 2008 | 11:08 AM
Starfury's Avatar
Starfury
Eh....I think it'd be a challenge to make it rigid enough to handle the force you're putting on it through the shifter.
Old Oct 21, 2008 | 12:31 PM
Adrenolin's Avatar
Adrenolin
You might want to look at http://www.4speedtoploaders.com/ in your research. Pretty much *THE* resource on toploaders.
