Hesitation at Acceleration
Old Oct 22, 2008 | 12:51 PM
MBDiagMan's Avatar
MBDiagMan
WADR - By recomminding such things as pointless ignition, which is always a good, practical mod, you are sending her down the path of throwing money at the problem rather than TROUBLESHOOTING the problem.
She has already begun her own troubleshooting by determining that the accelerator pump is apparantly working correctly.
She also is taking steps toward the second troubleshooting step in checking ignition timing. If the second step doesn't fix the problem, she will log in again with the results and we can help her with the next step.
Throwing parts(money) at a problem is never smart troubleshooting. In most of those cases you will be money and aggravation ahead by spending a few dollars for someone knowledgable to properly troubleshoot the problem.
She took the correct step by asking some questions so that she can try to troubleshoot it on her own. That's commendable. We will continue to help her as best we can. That said, let's try not to suggest $200 wild stabs at the problem.
Old Oct 22, 2008 | 03:42 PM
Norm Peterson's Avatar
Norm Peterson
Power valve malfunctioning? That's the other enrichment for part throttle acceleration, and the accelerator pump is apparently OK.
Where did the carb cleaner get sprayed to at least get the backfiring to stop?
Really long shot - are the carb hold-down bolts snug and is the gasket good?
Norm
Old Oct 22, 2008 | 04:38 PM
67ragtop's Avatar
67ragtop
It's likely to be a timing issue since it's otherwise fine while in 3rd and 4th gear. While you wait for your Ex to come over to check the timing, I'd say spend the $5 and change the fuel filter and test drive it. If it is still hesitating and backfiring, then check the timing.
I'd recommend to anyone to install a Pertronix Ignition. I believe even a non mechanic can install it, so it should only cost you about $60 plus tax.
Old Oct 22, 2008 | 04:39 PM
GroovyCalGirl's Avatar
GroovyCalGirl
OK gentlemen first thank you all for your help! here is what i did and it seems to be working .. well for one test drive at least.. I took off teh fuel line at the carb sprayed cleaner in teh line and the hole to the carb and then reattached tehm together.. Viola
Thank you for all your help!! Truly appreciate it
Old Oct 22, 2008 | 05:27 PM
67ragtop's Avatar
67ragtop
Great! I like a girl that isn't affraid to get her hands dirty.....
Thunderball
15
Nov 22, 2015 11:49 PM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Offendant
Sep 23, 2015 07:21 PM
SteelerNation82
Sep 16, 2015 07:11 AM
