holley design differences
Old Oct 26, 2008 | 12:12 PM
baxsom's Avatar
baxsom
Default holley design differences
HI,
I am rebuilding a used holley 750 vacuum secondary. It has center hung float bowls and dual inlets.
The bowls are totally gummed up and it is going to take a while to clean it all up.
I have a donor carb in the garage. It has perfectly clean side hung float bowls with that single inlet on the front bowl and the tube that runs to the back bowls.
Will there be a problem if i use the side hung bowls and transfer tube in place of the center hung bowls and dual feed design. They seem to bolt right up without a problem but I wanted to make sure.
It is going on my 72 454 vette if that makes a difference.
thanks
Old Oct 26, 2008 | 12:32 PM
ky's Avatar
ky
America ftw
why not get a few cans of brake or carb cleaner and soak that bitch?
Old Oct 26, 2008 | 02:09 PM
my77stang's Avatar
my77stang
yeah the other bowls will work, as long as both carbs have either 1 or 2 metering blocks, differences there change the length of the metal tube that connect the bowls but i believe almost all vacuum secondary carbs have only a front metering block.
but yeah, clean the damn bowls that came with it LOL center hungs are supposed to be better
Dokilar
15
Oct 16, 2015 08:13 PM
ChampInSD
Oct 2, 2015 04:55 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
UrS4
Sep 30, 2015 10:13 AM
