Shock tower repair time
Thank you Ford for this design flaw. Did it not seem to anyone at the time that this little "tray" where the shock tower meets the rail would hold crap and water?
Well, as holes go, these are not too bad. I plan on having a patch welded in for the shock tower. The rest of the tower is fine. A little surface rust in a few places, but that's all. I am wondering though if a larger plate to fit the entire exposed part of the top of the rail wouldn't be better than patching the hole in the rail.
I understand they also make a brace which fits over the rail and butts up to the tower. That would close in this little water trap completely, wouldn't it? Anyone done that?
National Parts Depot makes a patch panel that covers the frame rail and extends 3.5" high around the inside of the shock tower. Part #129-1 It won't stop water from getting trapped in there but it's 14 ga steel and you could probably modify it or add a few pieces of sheet metal to close off the water trap.
Funny thing is that when I went through my '66 I found the drain passage that was completly filled with seam sealer. If you prod around you'll find a large dart that's in the center of the inbord side of the tower that leads to the bottom of the channel the engine mount bolts onto. I cannot believe that they would not have left it open to drain, oh well the car was only designed to last 24 months.
Look at this http://home.flash.net/~sanco/mustang.htm the kits they sell only partly over that cup.
Well, I don't want to be the one to bust your bubble but, it looks to me like you need a frame rail to cure that cancer below the lip as well as your tower has a crack. Might also need to replace a section of that apron...I would keep grinding it down til I got to "good" metal and see what's left. The parts are pretty cheap...it's all labor.
