narrowing 9in?
Old Oct 26, 2008 | 06:47 PM
racin66coupe's Avatar
racin66coupe
Default narrowing 9in?
is it possible to narrow the 9in PAST stock, so that its shorter and i could use a wheel with less backspacing to get that deep dish look? and still use stock mounting points?
Old Oct 26, 2008 | 07:00 PM
andrewmp6's Avatar
andrewmp6
Ever seen a rear end in a dragster yes you can narrow any rear end.Your only limit is the spring prechs of you go with a link set up you can narrow it more.
Old Oct 26, 2008 | 07:05 PM
racin66coupe
i knew i COULD physicly, but i wasnt sure how close the perches were and whatnot. how narrow do you think i could go?
Old Oct 26, 2008 | 07:56 PM
eZ's Avatar
eZ
is it a stock 66 coupe?
Old Oct 26, 2008 | 08:12 PM
racin66coupe
well itll be in a stock 65 or 66 FB we bought, havent gotten it yet and there are some mispatched parts so we cant tell quite yet until it gets here
Old Oct 27, 2008 | 12:11 AM
Bentworker's Avatar
Bentworker
FYI
Moser will make you up a set of custom axles for about $350
Also, they offer narrowing of housings for $110. They are located in Indiana, shipping wouldn't be too bad for you. If you call up the tech line and get someone difficult to deal with, hang up and call again. One fellow I talked to was awesome, the other was a dud.
How narrow you can go will depend on your choice of rear brakes and wheels. Wait until you have all parts in hand before you make a choice on the rear end, I hate jumping on something only to mess it up.
Old Oct 27, 2008 | 12:13 AM
Aussie66Fastback's Avatar
Aussie66Fastback
you got a slight issue with the wheel arches unless you want to tub it
Old Oct 27, 2008 | 02:03 AM
andrewmp6's Avatar
andrewmp6
Get the car and make your mind up on wheels and brakes before you cut anything.
Old Oct 27, 2008 | 04:15 AM
kalli's Avatar
kalli
Daze once cut a rearend. I think he welded 8" tubes to a 9" housing or something like that.
Anyways a 9" will not fit a 64-66 Mustang as the wheel distance is shorter.
I got a 9" housing that is fabricated for a 64-66 from eBay for a good price.
quick performance racing. I can give you contact if you want.
The problem is if you want deep deep dish you might even have to cut shorter which will give the next problem: what axles to fit in there without cutting.
Might even want to talk to quick performance racing. Maybe they've done it before.
At least i know that they are knowledgable when it comes to 64-66 and 9" rears ..
Old Oct 27, 2008 | 07:12 AM
Gary H's Avatar
Gary H
You can only cut an inch or two off before you run into leaf spring problems. Axles are no problem, places like moser and strange can mahe them to any length for a decent price. They have all the info for measurements on their websites. Your best bet is to get the car and tires you want and set them in place without wheels to see how much room you have.
Personally I like this look better
http://mysticspeed.com/Copperstate/slides/s015.jpg
