EFI + 351w??
Old Oct 29, 2008 | 05:27 PM
boogerschnot's Avatar
boogerschnot
Default EFI + 351w??
I have read up on the EFI swap for the 302 and that seems pretty easy.. But does the same thing apply to the 351? Can I just find an intake and computer from a 351/5.8l truck and bolt her up. I think that could be an interesting swap.. Maybe a little more fuel effecient.
I know the deck height changes with the newer blocks.. Would that make a difference in finding an intake that will seal up correctly?
Any suggestions?
Old Oct 29, 2008 | 05:40 PM
racin66coupe's Avatar
racin66coupe
i think you could, but IMO, stock type fuel injection looks very out of place in a classic. i would go with a aftermarket type if you are going fuel injection at all. JMHO stay carbed
Old Oct 29, 2008 | 06:04 PM
4reboy's Avatar
4reboy
I've always thought about fuel injecting mine too... but that involves a lot of work I think, such as relocating the battery and such
Old Oct 29, 2008 | 06:30 PM
1971mach1's Avatar
1971mach1
Checkout this EFI link:
www.affordable-fuel-injection.com
They have a complete throttle-body injection kit for about $1300. The TB unit just bolts onto your intake where your carb was. Use a standard air cleaner housing so it still looks classic and no need to move your battery.
My 4.3L Chev Blazer had an TB-EFI similar to this. It looks just like a carb until you look down it's throat and see the injectors. Worked quite well too.
Old Oct 29, 2008 | 06:43 PM
Nick.Simonds's Avatar
Nick.Simonds
Have you used this?
Or anyone know of someone that has used this?
Old Oct 29, 2008 | 06:45 PM
4reboy's Avatar
4reboy
actually, Gothand has a 351 that he swapped efi on recently. PM him if he doesn't see this thread, not sure if he used a kit or anything.
Old Oct 29, 2008 | 07:46 PM
ky's Avatar
ky
America ftw
look into FAST efi.
Old Oct 29, 2008 | 08:24 PM
htwheelz67's Avatar
htwheelz67
the only 351w efi's were truck,van and lightning and cobra, the truck/van are very tall and speed density so cams,cyl heads are a problem, the lightning and cobra used gt 40 style intakes and fit bette AND are mass air type like the later 5.0's.
Old Oct 29, 2008 | 10:55 PM
andrewmp6's Avatar
andrewmp6
hood clearance might be tight with a oem efi set up.
Old Oct 29, 2008 | 11:06 PM
gothand's Avatar
gothand
Actually, I pulled the 351W when I redid the car and swapped in a Ford Racing 5.0L motor. That said, there have been PLENTY of 351W swaps into '87 - '93 Mustangs that it wouldn't be too difficult ... though not cheap. The only way to do an EFI swap cheaply is to use stock take-off parts. Once you start buying aftermarket manifolds, TB's, MAF's, high flow injectors, etc., the price starts getting up ther.
That said, I love having the EFI in my '65. Although I don't mind how it looks under the hood, I rarely have the hood open unless I'm performing maintenance.
