Chokostang or CSRP
Old Oct 30, 2008 | 06:56 AM
kalli's Avatar
kalli
csrp here as well. as you can see half the forum here used Dennises service, and that's for a reason. He was very patient with a lot of stupid questions of me in the past ;-)
Kalli
Old Oct 30, 2008 | 07:03 AM
blue66mustang's Avatar
blue66mustang
Have CSRP "Kelsey Hayes" on my 66. Bolts right on, took less than 2 days to install. Looks like it came from the factory...Stops on a dime and gives 9 cents change.
Old Oct 30, 2008 | 06:53 PM
degins's Avatar
degins
Originally Posted by rmodel65
about the drop spindles i have that ssbc setup, it would be incompatible with the large pin wouldnt it
The drop spindle will have an intergal bracket for KH calipers. I believe the SSBC caliper uses this bracket configuration.
Old Oct 30, 2008 | 09:06 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
my setup uses the 13 inch rotors
my calipers iirc had the regular style disc mount then an adapter for the 13 inch setup
Old Nov 1, 2008 | 10:32 AM
RagHead's Avatar
RagHead
Originally Posted by degins
I agree with the above on 5 lug 65-69 cars, but I still recommend the Granada kit for 65-66 4 lug because the Granada kit includes the 5 lug spindles.
FYI, I'm working on 5 lug 26 spine axle replacement for 6 cylinder 65-66 and 67-69. I'm also working on the long awaited drop spindle, and reproduction 5 lug 65-66 and 67-73 spindles, all with the large spindle pin.
The developement of a front SN95 PBR type 2 piston aluminum caliper and 1.025" thick 11" diameter rotor for Granada spindle is coming along well. Unlike the Cobra and SN97 brake conversions offered by others that have the calipers, brackets, and rotors laying 1-2" or more outboard from stock position, this set-up will reside at the stock position. In fact, I'll even offer dust shields.
Are you still work on the 5 lug 26 spine axle replacement for the 66-67 and 67-69 I6? If so, when/about when will they be available?
Old Nov 1, 2008 | 05:24 PM
degins's Avatar
degins
I will soon start prototyping. It will be a while. I currently have 5 projects in the pipe line.
Old Mar 24, 2009 | 05:20 AM
grendi's Avatar
grendi
hi dennis
i bought your kit a few month ago and it works great. i also have a rack and pinion from randall and like most other rack and pinion owners, i have a larger turning radius.
the steering arm is to long for the travel of the racks. (except maybe for the tcp ones)
would it be possible to design them in a way that would allow r&p owners to correct the turning radius.
for example by adding a second hole for the outer tie rods, or a removable steering arm like on the wilwood hotrod spindles?
Old Mar 24, 2009 | 08:36 PM
chillininnh's Avatar
chillininnh
Chokostang gets my vote, for a street car, why not keep it stock. Makes getting replacement parts down the road a lil easier.
Old Mar 24, 2009 | 10:05 PM
whitestang07's Avatar
whitestang07
how much does it cost for the front to convert to disc
Old Mar 24, 2009 | 10:21 PM
degins's Avatar
degins
Originally Posted by grendi
hi dennis
for example by adding a second hole for the outer tie rods, or a removable steering arm like on the wilwood hotrod spinles?
I've discussed this idea on the forums and it could probably be done as a special. Given the cost involved and the limited market, this would not be high up on my ever growing list of projects.
