Coolant overflow problem
Old Nov 3, 2008 | 04:06 PM
restomod66's Avatar
restomod66
Default Coolant overflow problem
After installing a new reconditioned radiator, we drove the car for approx 5
mile ride. Can ran OK temp wise except cooling water was pushed out the overflow hose on the radiator. I think a new 16-18 lb. cap should be installed. What do you guys think??
1966 GT clone with 70's 302 automatic with electric cooling fan set-up.
Old Nov 3, 2008 | 04:10 PM
Adrenolin's Avatar
Adrenolin
Didn't quite understand... Is the coolant coming out of the Rad Cap or from the overflow valve? Do you have an overflow tank hooked up?
1965fastback's Avatar
1965fastback
You might have an air bubble in your system.
Old Nov 3, 2008 | 04:14 PM
fakesnakes's Avatar
fakesnakes
You need to install a coolant recovery tank, otherwise the coolant is expelled past the radiator cap and dumps on the ground. The tank has that hose from the radiator cap connected to the bottom and a vent hose on the top. When the engine comes up to temperature, coolant expands and pushes past the radiator cap and into the tank. As the engine cools the coolant is drawn back into the radiator. You also use the tank to top off your radiator.
Old Nov 3, 2008 | 05:00 PM
restomod66's Avatar
restomod66
Coolant is leaking from theoverflow hose, so I agree on the recovery tanks. Any suggestions on type??
Old Nov 3, 2008 | 05:31 PM
boogerschnot's Avatar
boogerschnot
I have a buddy that makes overflow tanks out of booze bottles. He just made one out of a jack daniels fifth. he took a pensil holder cut it and welded back together to fit the bottle and then bolted it the fender wall of his 69 Chevy truck and then ran his line to it.. I want one..
Old Nov 3, 2008 | 05:40 PM
wumarshall82's Avatar
wumarshall82
Here is the one I put in from advanced auto ($7). Not the prettiest but it was cheap and got the problem fixed (pretty much the same. coolant coming out of the tube onto the ground). Someone posted one from NAPA that was chrome and pretty nice. I'll change it eventually but I'll put the money somewhere else right now.
Adrenolin's Avatar
Adrenolin
We need a photo... (Like you didn't see this post coming)
Old Nov 3, 2008 | 06:27 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Don't get a plastic job. Everybody will wince when they see that as soon as you lift the hood. Get a nice stainless tube type that you can mount next to the radiator. They can be had for 25 or 30 bucks and look good. Nothing flashy or trashy.
Old Nov 3, 2008 | 06:50 PM
fakesnakes's Avatar
fakesnakes
I prefer the plastic ones like this one for $30, only because you can see how much fluid it contains. It doesn't look as cheap as the universal part store one and is far less expensive than most of the aluminum and ss ones:
http://store.summitracing.com/partde...5&autoview=sku
