'67 Motor Size?
Old Nov 11, 2008 | 11:05 AM
sIx's Avatar
sIx
Default '67 Motor Size?
I have a '67 notch back that came original Straight 6 and a 3 spd tranny. I need a new engine and want a v8. I was wondering If a 390 motor would fit it? If not, whats the biggest I could drop in?
Old Nov 11, 2008 | 11:21 AM
MBDiagMan's Avatar
MBDiagMan
Sure, you can get a 390 in it, but IMHO this makes a dog out of most any Mustang. You are adding LOTS of weight to the front which will make it nose heavy. This will cause it to handle like an oversped farm tractor.
You would be much better served to use a Windsor motor of some description. They can be built for LOTS of torque these days. Given the light weight of your Mustang a Wndsor motor will make it fly. Don't forget to upgrade the transmission, rear axle and brakes while you're at it.
Better yet, sell your six cylinder car to someone who wants an economy ride and buy one of the gazillion early Mustangs that are always on the market.
My $0.02,
Old Nov 11, 2008 | 11:25 AM
Waffles's Avatar
Waffles
From: Detroit; where the weak are killed and eaten.
351W FTMFWWWWWWWWWWWWWWWW
Old Nov 11, 2008 | 11:30 AM
sIx's Avatar
sIx
Only problem with that, is that around here, its actually kind of hard to find a DECENT '60 somethin mustang that does not cost a fortune, or in **** poor condition. That and I was considering making it a drag car...but not sure..
Old Nov 11, 2008 | 11:41 AM
dodgestang's Avatar
dodgestang
Many v8 motors fit without any major surgery in a 67.
289 - 460 lbs
302 - 460 lbs
351w - 500 lbs
351c - 550 lbs
390 - 625 lbs
427 - 625 lbs
428 - 625 lbs
429 - 720 lbs
460 - 720 lbs
http://www.mustangsandmore.com/ubb/E...imensions.html
What are you goals for the car? use for the car? budget for the car?
These are the 3 things that are really governing your motor choice.
Old Nov 11, 2008 | 12:23 PM
coolhnd9's Avatar
coolhnd9
Use a jet engine and call it a day! Just kidding... I think the guys above covered it quite well!
Old Nov 11, 2008 | 01:14 PM
retro77's Avatar
retro77
You can save weight on a 390 buy ditching the cast iron heads, intake and manifolds. Go aluminum and you'll easily save 200 lbs.
You'll need to ditch that tranny and get yourself a C-6. Probably need to upgrade the rear end to a 9 inch. New axles for the 5 lugs.
The comments that a 390 makes a Mustang a dog, I challenge your words.
Old Nov 11, 2008 | 08:20 PM
sIx's Avatar
sIx
Going Aluminum is what I would do. And not to sure about budget, but I am willing to spend money to get good parts. I just want her to smoke the tires if you gave it a little bit too much gas, or more like a street legal drag car... Think a 4 or 5spd and 9" 4:10 setup?
Old Nov 11, 2008 | 10:22 PM
andrewmp6's Avatar
andrewmp6
Id use a 429 or 460 over any fe.Don't forget you need the big block springs in the front if you use either big blocks.
Old Nov 11, 2008 | 10:29 PM
sIx's Avatar
sIx
Are springs all you would need suspension-wise for a swap?
And If I do go through with this, would I have to mod anything to get the trans. to mount?
