Stroker Crushed and Ripped my Spring Perches
Old Nov 11, 2008 | 10:19 PM
andrewmp6's Avatar
andrewmp6
You got a 8 inch or 9 inch? If you keep the leaf springs you need a panhard bar or watts link they will keep the rear end from moving around too much.
Old Nov 12, 2008 | 08:26 AM
urban_cowboy's Avatar
urban_cowboy
I will look into a panhard bar or watts link and read up on them.
I have a Ford 9" rearend with 31 spline Moser axles and a bad ars factory limited slip. The PO put them in and I have never changed them out. It will haze the tires a little on a launch and the marks are perfectly straight and the same length. The leaf springs, traction bars, and MT Sportsman tires do not allow for much slippage, so the axle just tries to rotate. This is good and bad. It means I am planting mas power but it also means that the stock stuff is starting to break.
Old Nov 12, 2008 | 10:53 AM
andrewmp6's Avatar
andrewmp6
Both a panhard bar and watts link keep the axle centered but it can still move up and down but not left and right.Panhard bar is good for drag racing a watts link is better for road racing.Only downside is the exhaust out the back might be a little tricky to pull off.
Old Nov 12, 2008 | 11:56 AM
coolhnd9's Avatar
coolhnd9
Wow, this is an interesting write up and pics! Thanks for sharring! You've got your car hooking pretty good to be able to turn those perches into a tuna can like that!
Old Nov 12, 2008 | 01:36 PM
quesey's Avatar
quesey
get a set of aftermarket perches put them on and weld strap over housing to front and back side of the perches as wide as the perches.it will keep from doing that agian.happened on my torino once
Old Nov 12, 2008 | 04:19 PM
Norm Peterson's Avatar
Norm Peterson
I don't know offhand what your traction bars look like or how they attach, but if they attach either using the leaf spring U-bolts or clamp directly to the leaves, the axle torque reaction load goes through the leaf spring perches. In that case, the perches need reinforcement since it is now known that the perch is the weak link in that load path. If you're going to keep the leaves, anyway.
Norm
Old Nov 12, 2008 | 07:02 PM
cprstreetmachines's Avatar
cprstreetmachines
Just buy aftermarket leaf pads. Have been in the low 1.4's now and still nothing wrong with them yet, knock on wood.Aftermarket versions are much thicker.
Old Nov 12, 2008 | 07:29 PM
fakesnakes's Avatar
fakesnakes
CPR is right on target. I have a Currie 9 inch in my '66. In addition to much beefier perches, they are completely welded to the tube, and use 3" axle tubes. Compare the after market perches to your stock perch and you will see a huge difference.
Old Nov 12, 2008 | 08:53 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
please for the love of god tell me that they came out with a stroker kit for a 351 that makes it 383 and you dont have a chevy in that mach
please?
anyways, that sucks, hope you get that fixed, sounds like your making some good power
Old Nov 13, 2008 | 12:50 AM
valley firearms's Avatar
valley firearms
LOL! Welcome to the club. You'll be replacing parts every time you go out if you drive like me. My Cal Tracs didn't stop my perches from rolling, nothing will until you replace them with beefier ones or box them in like I did after I replaced mine. When my perches rolled it broke my third member. I too did this on a rolling start. I never juiced it off the line because I was paranoid as well.
Attached Thumbnails Stroker Crushed and Ripped my Spring Perches-9-rear-017.jpg   Stroker Crushed and Ripped my Spring Perches-9-rear-031.jpg   Stroker Crushed and Ripped my Spring Perches-9-rear-051.jpg
