another wheel question... 67'
Old Nov 13, 2008 | 06:20 PM
polo708's Avatar
polo708
Default another wheel question... 67'
I want to run wide tires on the back of my 67 coupe, something in the ballpark of 275's on an 18" rim. I plan on running a fully adjustable rear end with coilovers or even possibly a jaguar IRS. Im curious what specs I should stick with in the wheel to avoid problems with rubbing and/or stressing the rear end. Things like offset, backspacing, rim width(9" or 10"). Any suggestions are appreciated.
Old Nov 13, 2008 | 06:49 PM
dodgestang's Avatar
dodgestang
http://www.dodgestang.com/cgi-bin/pr...0Wheel%20Chart
Old Nov 15, 2008 | 01:12 AM
polo708's Avatar
polo708
how do I read that? Is the backspacing number the max you can run?
If the backspacing number on your chart shows 5.5" for my setup and the specs on the rim I want shows 5.94"... does that mean im good, or will it not work?
basically I want to run some of these on my 67 coupe with a 275/40R17 tire:
http://www.americanmuscle.com/chfrwh1.html
also, do you see these working on the rears with the above on the front?
http://www.americanmuscle.com/chrome...l-17x10-5.html
Old Nov 15, 2008 | 08:12 AM
dodgestang's Avatar
dodgestang
The chart shows what people are running and if/how it works for them on their cars.
If you are looking at a wheel that is the same width but has more backspacing....chances are it won't work, but there is enough information in the chart to extrapolate some answers
The 17x9 linked have late model BS you would need a bolt on adapter to use them in the front, people who have run that size in the rear have also used 1/2 spacer in the rear. I also don't think I have anyone on the chart who has successfully run a 10.5 wheel. I also don't think 275s are going to work too well on the front.
Old Nov 15, 2008 | 08:46 AM
polo708's Avatar
polo708
Thanks... I planned on running a smaller size on the fronts and a wider size on the rears. Guess I need to find a smaller wheel.
Old Nov 15, 2008 | 09:15 AM
dodgestang's Avatar
dodgestang
17x8 front and 17x9.5 rear is a proven combo.
Old Nov 15, 2008 | 09:25 AM
polo708's Avatar
polo708
nice, I think im going with that then... whats the widest tire you've seen on a 17x9.5? will 275's fit the rim?
you've been a huge help, thanks.
Old Nov 15, 2008 | 09:58 AM
dodgestang's Avatar
dodgestang
The info is on the chart. I am on mobile right now so I can't look it up.
Old Nov 15, 2008 | 10:22 AM
newbie68's Avatar
newbie68
Ok guys. Right now I am running the stock gt style argent steel which are 14's. I want to go to a Torque Thrust 2 or Bulolit Take off in a 17 because I am told the Disc Conversion wont work with my stocks. Is this true?
Old Nov 15, 2008 | 10:31 AM
htwheelz67's Avatar
htwheelz67
I'm running 17x9.5 and 275's on my 67
http://htwheelz.smugmug.com
