Reverse Slow to Engage?
Old Nov 15, 2008 | 06:24 PM
quesey's Avatar
quesey
i'm going to back valley on what he said about not workin at all after fluid and filter change it could go all together.if you really want to change fluid just drain fluid and get some carb cleaner and spray the filter clean as you can still on the valve body without unbolting it.had a c4 once in a car that worked pulled motor and trans out and put it in another car 2weeks later and trans made it out the driveway then quit i'd guess from tilting and rattling it around broke some of the trash around.i'd try the brake fluid trick first it wont hurt or cost much like i said if its a seal it will help unless trans is to bad allready
good luck
4cylinderplus2
Oct 9, 2020 07:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
guitarman376
Sep 30, 2015 05:54 PM
RCS02v6
Sep 29, 2015 01:46 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
