Metallic tapping sound in reverse?
I recently had dual exhaust installed on my 66 Mustang. The day I picked it up I noticed an odd metallic tapping in reverse that changed with the RPMs. I checked around the driveshaft thinking the installers may of get something too close but I haven't found anything. Today I noticed that if I park the car on level ground or with the nose facing down I get the odd tapping. If I park the car with the nose facing up I don't get the tapping. I checked the fluid levels and they're good. I've had the car a year and only since the exhaust was installed 2 weeks ago I noticed this issue.
It's a stock 289 with a 2 year old rebuilt 3 speed automatic. Has anyone else heard of this problem? I'm totally lost which isn't a suprise, I know nothing about transmissions.
check the tranny mount, might be bad causing a misadjusted linkage. and check the linkage itself
if its out of adjustment you can hear the park pawl popping and it will back up
