new engine broken
Old Dec 3, 2008 | 09:53 PM
65Rocky's Avatar
65Rocky
Default new engine broken
Started my first rebuilt engine and a few minutes later bang and then the engine, stopped, no gas?.
So I checked and found that the eccenitic? was broken off,but still in the timing cover, I used a magnet and retrieved it out.
wht did it brake.
the eng. is a 5.0 with 65 timing cover.note the eccenitic was not round but 1/4 round.
Old Dec 3, 2008 | 10:00 PM
Iskwezm's Avatar
Iskwezm
did the pin break, the bolt or the actual eccentric?
Old Dec 3, 2008 | 10:06 PM
65Rocky's Avatar
65Rocky
the eccintic only I think, the cover is still on, a light and mirrior to see
Old Dec 3, 2008 | 10:18 PM
woodsy's Avatar
woodsy
Those are junk, use a full round steel 1 piece, long dowel pin.
Old Dec 3, 2008 | 10:23 PM
my77stang's Avatar
my77stang
i like the 2 piece rounds myself, seems like there should be less friction somehow.
Old Dec 3, 2008 | 10:24 PM
65Rocky's Avatar
65Rocky
I know, should of put the round one on, thought about it, but did not do it, Shi>@.
will have to take the timimg cover off and see what left, and change the oil asap.
Old Dec 3, 2008 | 10:35 PM
65Rocky's Avatar
65Rocky
Is there something wrong to cause this? I have never heard of this before
Old Dec 3, 2008 | 11:58 PM
my77stang's Avatar
my77stang
if it just snapped, you wouldnt have to even change the oil cept for you'll probably get crap in the pan while cleaning up the timing cover gasket remnants
Old Dec 4, 2008 | 07:05 PM
65Rocky's Avatar
65Rocky
Default which eccentric to get
I :confused, need to replace broken eccentric, what should I get?
stock 5.0 with alum. heads, 600 elder, hooker headers.
old one was a 1/3 eccentric 1 or 2 piece
Old Dec 4, 2008 | 11:52 PM
quesey's Avatar
quesey
wht did it brake.
the eng. is a 5.0 with 65 timing cover.note the eccenitic WAS NOT ROUND but 1/4 round.
Theres your problem it is not made to run a pump.efi motors dont have the
eccentric to run a pump just need one of the other kind both will work
