1965 Master Cylinder Upgrade
Hello,
I've got a 6 cylinder '65 coupe with standard drum brakes, a fruitbowl, and brake lines that are in need of replacing.
I want to replace the fruitbowl with a dual bowl master cylinder, and replace all the lines.
Can I simply use a master cylinder and brake lines for a '67 to do this job?
Where would be the best place to source those parts?
Thanks,
Fred
Thanks,
Fred
You can use the '67 m/c, but you need to keep the pushrod. The lines you need to bend yourself. Any parts store should have plenty of hard lines available. I recommend Napa's poly-armor brake lines for easier kink-free bending.
I just asked this a couple days ago.
Napa carries them , or you can go this route: http://www.parts123.com/parts123/yb....Z5Z5Z50000016e
You can use the prebent brake lines for your car, you will need to rebend them to make the mc connections, but the straight pieces from NAPA are much cheaper and require more work to get them perfect.
i ended up completely redoing the brake system pretty much.
thermoquiet shoes in the front
normal shoes in the rear
turned all 4 drums down
new prebent hardlines for the entire car
new hoses for the entire car (3)
new dual bowl MC
4 new wheel cylinders
only thing left was the spring kits & dist. block for th fluid
