2V or 4V
Old Jun 1, 2005 | 05:21 PM
BillyBobJoe's Avatar
BillyBobJoe
Default 2V or 4V
First, is the carb. 2, or 4, bbl or is that determined by the engine?
Second, how do i know what I have? I assume if you look down the carb and you see two little round things, you have a 2bbl but I wanted to make sure. In the trunk of the car was the top to an air cleaner that had the 4V sticker on it, but i only see 2 "bubbles".
Thanks in advance.
Old Jun 1, 2005 | 05:29 PM
horseshoeing's Avatar
horseshoeing
Default RE: 2V or 4V
Click this link http://www.holley.com/HiOctn/ProdLin...C/StLegal.html
Does your carb look like this?
Old Jun 1, 2005 | 05:43 PM
Soaring's Avatar
Soaring
I ♥ Acer
No, it's determined by the intake. Here is a 4V carb. If yours only has a two venturi, then it is a two barrel.
Old Jun 1, 2005 | 06:51 PM
horseshoeing
And the cam and the heads
Old Jun 1, 2005 | 07:09 PM
69mach1377's Avatar
69mach1377
Soaring it correct.
V stands for venturi or holes in your intake manifold that lead to your cylinders. You typically want as many 'barrels' in your carb as you have 'venturis' in your intake. Cam and heads are of less consequence in this respect.
