what are your oppinions on the global west sub frame connectors?
Old Dec 13, 2008 | 11:38 AM
racin66coupe's Avatar
racin66coupe
Default what are your oppinions on the global west sub frame connectors?
just wondering.. do you need to cut the floors at all? how do they fit? etc etc
thanks!
Old Dec 13, 2008 | 03:13 PM
fakesnakes's Avatar
fakesnakes
I put them on my 66 and the 70 Mustang I built several years ago. In both cases, they slid right into postion and were easy to weld on, with no trimming of anything.
Old Dec 13, 2008 | 03:27 PM
Adrenolin's Avatar
Adrenolin
I went with the Tin Men connectors. Once installed they are a perfect extension from front to back and look correct unlike the round tubular connectors.
Old Dec 13, 2008 | 04:20 PM
racin66coupe
how much were the tin man ones? do they come ready to weld on? i think some need to be bent and whatnot?
Old Dec 13, 2008 | 04:23 PM
racin66coupe
awesome, just saw em. not a bad price either! thanks!
Old Dec 13, 2008 | 05:36 PM
68EFIvert's Avatar
68EFIvert
I have GW subframe connectors on my convertible and the fit was horrible. I had to cut off the front mounts and then reweld them back on. They were not even parallel to the mounting points. They were off about 10 degrees. Once that was corrected they work and fit great.
Old Dec 13, 2008 | 06:20 PM
racin66coupe
hmm.. seems like tin man it is
Old Dec 13, 2008 | 06:26 PM
Adrenolin's Avatar
Adrenolin
racin66.. 65-73 Mustang Subframe Connectors .. 145.00 and free USPS Priority shipping. Cut the back ends off the front rails, slide the connectors in, weld them up. Well.. a bit more than that but thats the gist of the install. They follow the floor lines nicely, no floor cutting needed on coupes/fastbacks (verts might iirc) and look pretty stock.
I was shocked at how much they stiffen the car! Well woth the 145.00 bucks and its something every classic mustang should have done imo.
Old Dec 13, 2008 | 06:29 PM
racin66coupe
awesome. thanks! is it the back of the floor support that you cut?
Old Dec 13, 2008 | 06:43 PM
Adrenolin's Avatar
Adrenolin
yeah its the back section .. ehh.. Here is the Tin Man Instructions
I had the floor pans out while installing so I was able to add full welds inside the frame extensions along the top of the connectors in addition to 6 plug welds on each side of the extensions. I made up new extensions as ours were bad and they were a bit longer allowing for the additional plug welds. Quite easy install actually.
