vibration problem help
Old Nov 2, 2003 | 06:40 PM
pmfstang68's Avatar
pmfstang68
Default vibration problem help
I was wondering if anyone new what could be cuase vibration at high speeds around 80mph. I just got a new torque converter, transmission mounts and a new drive shaft and i still am having a problem but it is not as bad at all form before. anyone have any suggestions of what it could be it is driving me in sain.
Old Nov 2, 2003 | 07:04 PM
quig's Avatar
quig
Probably a tire or alignment problem.</P>
Quig</P>
Old Nov 2, 2003 | 07:20 PM
pmfstang68's Avatar
pmfstang68
i just got it aligned and tires balanced about a month ago and don't think it is that but thnx though maybe it could be
Old Nov 3, 2003 | 11:32 AM
quig's Avatar
quig
Are all your control arm bushings good along with all other front end parts. Also what kind of wheels do you have? I used to have aluminum slots and they were balanced but the weights were stick on and were a nightmare. I switched to styled steel wheels and solved my problems. </P>
I did have a severe vibration about 15 years ago and it turned out the flywheel I got from a swap meet was for a 240 6 cyl same dimensions but different balance. I knew it was a rotating part on the engine and changed water pump alternator ps pump and even the cam, then it hit me to get the number off the flywheel and bingo bought a hays and vibration gone. Also the lighter flywheel lets me use an 11" clutch and revs quicker.</P>
Quig</P>
Old Nov 5, 2003 | 09:17 AM
Taifun38's Avatar
Taifun38
First of all make sure your new driveshaft is properly mounted, especially that the rear u-joint is fully seated in the pinion yoke and if new u-joints have been mounted check to see if these are seated properly. The front yoke should have about 1" clearance in to the transmission before it bottoms out. Drive the car, when the vibration occurs put the transmission in neutral and let the engine idle, if it still vibrates(high frequency) it comes from the driveshaft assy.</P>
Good luck!</P>
Old Jan 17, 2004 | 03:08 AM
mstngmach's Avatar
mstngmach
Pinion angle. That one that most people overlook.
Old Jan 24, 2004 | 10:57 AM
Boss9er's Avatar
Boss9er
Wheel balance problems always seem to show up around 60 mph, Incorrect flywheel balance usually at 1K to1.2K RPM,so I would look at driveshaft balance and/or pinion angle. It seems the latter is almost always overlooked.<IMG src=smileys/smiley16.gif border="0">
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
