Edelbrck 2121 Intake Bracket?
Old Dec 16, 2008 | 07:43 PM
runway1's Avatar
runway1
Default Edelbrck 2121 Intake Bracket?
I noticed that the Edelbrock intake manifild instructions suggest a throttle bracket adapter likes these:
http://store.summitracing.com/partde...5&autoview=sku
Which one? Are they really needed and if so, why are the two so different? Who has installed one on their 302? I'm using one with a Edelbrock 2161 carb. Thanks.
Old Dec 16, 2008 | 10:38 PM
REAVER117's Avatar
REAVER117
You probably will need both. The first one is an automatic transmission kickdown bracket, and the second lets you mount the throttle cable to the intake. I needed both when I installed the Edelbrock 2121.
Old Dec 17, 2008 | 08:30 AM
rbrown22's Avatar
rbrown22
I didn't need either for my '65.. 289. I just had to drill a small hole in the throttle cable for my Edlebrock carb connection. I was able to make my '65 kick down bracket work just had to trim a little off front to fit on the intake. I'm planning on getting a '66 kick down which is a lot better than '65 and doesn't connected to intake but you have to swap the pedal.
Old Dec 17, 2008 | 08:59 AM
runway1's Avatar
runway1
I hope I can make my existing brackets work. Adding another $39 + shipping is a gouge for a $160 manifold.
Old Dec 17, 2008 | 09:40 AM
rbrown22's Avatar
rbrown22
I can show you some pictures of my setup.. It may help..
Old Dec 17, 2008 | 04:42 PM
runway1's Avatar
runway1
That would be great. I pm'd you or you can post them here. Thanks!
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Explosive
Oct 2, 2015 07:45 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
