302 for 66’
Old Nov 2, 2003 | 09:22 PM
Jonnyyuma's Avatar
Jonnyyuma
Default 302 for 66’
Hello,</P>
i am going to be putting in a 302 and new tranny into my 66' sooner or later. i was wondering if there was any major suspension work i would need to do. i believe the car had a 289 origanally? now it has a straight 6, dont' know the ci; i havent' checked what make it is. also is it hard to put disc brakes on and does anyone make a kit?</P>
thanks for the help,</P>
jonny</P>
Old Nov 3, 2003 | 01:31 AM
67aquafastback's Avatar
67aquafastback
Default 302 for 66’
What is the vin code. You will be able to tell if it was a v-8 or inline six. Does it have 4-lugs or 5 all Sixes had 4 lugs.
Old Nov 3, 2003 | 01:32 AM
Jugador1's Avatar
Jugador1
I ♥ Acer
Default 302 for 66’
i dont see much reasoning in switching to the 200...but im sure you have reason to believe it was switched
Old Nov 3, 2003 | 11:10 AM
quig's Avatar
quig
Default 302 for 66’
If you have 4 lugs I have complete spindle and drun assemblies from a 67 5 lug that will fit a 66 if car was originally a 289 it will already have 5 lugs. To switch to discs is not hard and yes there are kits but they are very expensive. I used the spindles and brakes from a 71 ranchero since they mount without any changes except 71 tie rod ends are needed. I also had to modify the master cylinder push rod from a later model and use a disc brake proportioning valve. I was lucky to have the whole vehicle, was in decent shape except the frame rails are gone. I'm glad I didnt knuckle under to the ole lady to get rid of that P.O.S. next to the garage.</P>
Quig</P><edited><editID>quig</editID><editDate>37928.388125</editDate></edited>
Old Nov 5, 2003 | 10:28 PM
Jonnyyuma's Avatar
Jonnyyuma
Default 302 for 66’
[QUOTE=quig]
Quig</P>
How much do you want for the spindles? i plan on switching to disc brakes so i will wait on the drums.</P>
jonny</P><edited><editID>Jonnyyuma</editID><editDate>37930.8545717593</editDate></edited>
Galactic
Apr 29, 2019 02:56 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
69Volunteer
Sep 30, 2015 10:39 AM
jaiidutch
Sep 14, 2015 10:29 AM
