exploder rear disk brakes
Old Dec 22, 2008 | 03:52 PM
valley firearms's Avatar
valley firearms
Default exploder rear disk brakes
I've been sitting on a set of exploder rear disk brakes for over a year now. I've been threatening to do the Granada disk swap (I have two sets) and the rear explorer swap. I've recently read that the exploder rear disks will only work on big bearing 9" rears. Can someone explain why and if there is a mod other than cutting the end of the tubes off and re welding the big bearing ends on. Thanks!
Old Dec 22, 2008 | 04:08 PM
Nick.Simonds's Avatar
Nick.Simonds
Something I want to know too is can you use a parking brake with this set-up?
Old Dec 22, 2008 | 04:17 PM
fakesnakes's Avatar
fakesnakes
Here's why:
A Lokar parking brake cable can be used and ties in with the stock set up.
Old Dec 22, 2008 | 04:39 PM
valley firearms
It appears the center to center bolt pattern is bigger for the disk brakes?
Old Dec 22, 2008 | 06:22 PM
67 evil eleanor's Avatar
67 evil eleanor
I have used two sets of Explorer disc. The bolt pattern was a little off on the small bearing housing so I enlarged the holes on the brackets to fit, its not a biggie. One set is on the track car and has seen some rough use. On the emergency brakes, you need to cut the Explorer cable about a foot in front of the connector that is under the drivers area. This then can be attached to the fulcrum on the park brake assembly on your car. Also you will need a set of spacers. These need to be the thckness of the brackets and will hold the bearing firm.
Old Dec 22, 2008 | 07:25 PM
valley firearms
It seems that I have seen pics of those plates that someone fabricated. Does anyone have any pics or a link that will show these plates?
Old Dec 22, 2008 | 09:27 PM
Nick.Simonds
So they CAN be used on either? Just a little machining?
Old Dec 23, 2008 | 08:42 AM
kalli's Avatar
kalli
just to add to Marks comment:
I can confirm there's a Lokar parking brake kit that can be used with the explorer discs. It's what I'm running as well
I BLELIEVE that onme is the one I got (I just had to cut the cables a tad the rest went in no prob):
http://store.summitracing.com/partde...5&autoview=sku
This kit contains the Clevis kit you will need to attach to the ford explorer brakes
See here:
http://www.lokar.com/interior_pages/...rake_cable.jpg
Kalli
Old Dec 23, 2008 | 08:44 AM
fakesnakes's Avatar
fakesnakes
Kalli, that is exactly the set up I have and it works very well.
mtgldr
Feb 3, 2024 09:00 PM
Galactic
Apr 29, 2019 02:56 PM
musnicki
Sep 23, 2015 07:11 AM
DoctorScary
Sep 9, 2015 07:53 AM
