place marking
Old Dec 24, 2008 | 08:20 AM
SJs 66coupe's Avatar
SJs 66coupe
Default place marking
Ok, fair warning ahead of time but this might potentially be a "stupid question" but....
I finally found the piece of trim that goes where the dash pad meets up with the windshield. Apparently, they don't make this piece reproduction but I found a place that has a bone yard and they were selling media blasted / primed pieces off of old junkers.
One side, the holes lined up perfect. The other side was way off so I finally said screw it and carefully drilled new holes.
I need to take this piece off for a project but before I do I want to mark the windshield in some fashion to make the holes easier to line back up when I get around to the reinstall. I was thinking it would be easy enough to make a small mark on the windshield.
What can I use to make some small marks that can be cleaned off after all is done?
I thought about something simple like a sharpie marker but will I have any luck cleaning something like that off the glass later?
Old Dec 24, 2008 | 09:07 AM
ThanksDad's Avatar
ThanksDad
Lipstick, lumber crayon, or a make up pencil should all come off easy. Or put tape down first and then use a sharpie. You will probably need a razor blade to clean up the tape.
Old Dec 24, 2008 | 09:51 AM
Joe67's Avatar
Joe67
Banned
sharpie will come off glass with lacquer thinner, acetone, rubbing alcohol, and pretty much any solvent like that
Old Dec 24, 2008 | 10:25 AM
SJs 66coupe
I figured it might come off with a bit of nail polish remover, rubbing alcohol, etc but I didn't think the wife would appreciate me testing the theory on her PT Cruiser's windows first, LOL!
Old Dec 24, 2008 | 10:48 AM
blue66mustang's Avatar
blue66mustang
Wax pencil should work.
Old Dec 24, 2008 | 10:54 AM
Norm Peterson's Avatar
Norm Peterson
Acetone removes most adhesives without even leaving a streak. I use it all the time to clean up after removing autocross tech inspection stickers (penny-sized stickies).
Probably not the hot tip for use on aftermarket tint though.
Norm
Old Dec 25, 2008 | 12:49 AM
SJs 66coupe
I ended up using a Crayola crayon that the boys had...they were coloring earlier this evening and it gave me the idea.
Tested it first and it doesn't rub off with a slight / accidental touch but if you get a rag and use slight elbow grease it comes off easy enough :-)
baddog671
Jul 26, 2016 01:20 PM
Dokilar
15
Oct 16, 2015 08:13 PM
fastbackford351
Oct 1, 2015 12:24 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
